Denon DL-60?DL-1000A?
As you probably know already, stylus replacement down the road is the drawback with moving coil.
Good model, just need to buy a better needle than the factory oneDenon DL-60?![]()
I've tinkered with the siblings that are the Excel 700, A&R P77 and Sumiko Black Pearl, and tried various styli combos. With one of them, I got an SAS MM1 stylus that was supposed to have "some life left in it", but alas it was way past its due date, with R channel really drooping from 5kHz and on. L channel looked OK, and if that's anything to go by, it's not closer to linear than the P77 or the Sumiko.The ones produced today for linear response; Nagaoka MP-500, Ortofon super OM30, or a JICO SAS/B for Shure V15-VIII, -VIV or Vx. JICOs seem to vary a bit in the top octave. Would love to see Sumiko Pearl with SAS MM1 stylus measured.
I did dig, and found a plot for a Kontrapunkt b - can't vouch for it, but to me it looks more of what that cartridge should look like.
Which suffix? Mine is the 700F, kinda rare and has the lowest inductance of them, which isn't too great, since it doesn't respond much to capacitance changes... You can check my A&R P77 measurement to see what kind of results to expect from your Excel. Sadly, the P77 stylus won't fit the Excel cart unless you remove just about all of the plastic housing... The MM1 does fit, but if I were to get an SAS, it'd be for another cart.Funny, I bought an Excel 700 from Japan two weeks ago. Haven't had a chance to run it, and then Milton crashed the party. Could be a sleeper cart, and styli are available.
I'm glad you were wrong.I was wrong, apologies... ES 75QL
S-75QL Stylus for Excel ES-75QL | DaCapo Audio
Get Your S-75QL Stylus for Excel ES-75QL from Denmark's International Turntable Specialist. Browse Our Full Range of Top-Quality Excel Replacement Needles that will Renew the Performance of Your Excel Phono Cartridgewww.dacapoaudio.com
DL-1000A?
https://www.audiosciencereview.com/...easurement-library.46108/page-34#post-1802028I don't think Shure with Jico Sas is linear, but maybe I'm wrong.
Of course, the results published here should not be taken seriously, there are too many unknown parameters here for them to be reliable results. For this, it is enough to set the cartridge slightly differently and the measurement result will be different.
2. Drawing conclusions like this cartridge is better or worse because it has a more or less linear bandwidth is completely pointless.
you posted numerous audacity plots over at shf showing what you thought was your great compliance matches of cartridges to tonearm and low amplitude resonance, only to find out here that you have signal chain issues as half the graphs you post have unnatural low end rolloff. the users here have taken the time to sort out issues when they post measurements and when something looks off, they ask for help.1. Of course, the results published here should not be taken seriously, there are too many unknown parameters here for them to be reliable results. For this, it is enough to set the cartridge slightly differently and the measurement result will be different.
3. However, as good fun such measurements make sense, and the thrill of waiting for Spyder to draw a graph is priceless.![]()
