Not too different from OM10.Ortofon Concorde 20 First Version, probably around 1979.
New Old Stock, out of the box, never used.View attachment 397625
Well, that's strange, because it has a Fine Line cut, but the tip is joined, it's not made entirely of diamond.Not too different from OM10.
OM10 is also bonded, so a bit heavier moving mass than the 0M20-40 range. Re: fine line vs more coarse tips, high frequency differences are mostly seen in inner tracks. You can reduce R to tame the peak as well.Well, that's strange, because it has a Fine Line cut, but the tip is joined, it's not made entirely of diamond.
This version of Concorde is of the MI type, the bracket is finished with a metal rod, and the magnet is permanently mounted.
The manufacturer recommends a charging capacity of 400 pf, unfortunately I had no way of setting this parameter.
The insert is very light, which is why the manufacturer includes an additional weight mounted on the arm.
In fact, any phono cartridge that does not have a linear frequency response throughout the entire range presents a false sound.OM10 is also bonded, so a bit heavier moving mass than the 0M20-40 range. Re: fine line vs more coarse tips, high frequency differences are mostly seen in inner tracks. You can reduce R to tame the peak as well.
Yes. However, slight peaking 10-20 kHz is less audible.In fact, any phono cartridge that does not have a linear frequency response throughout the entire range presents a false sound.
Am I thinking correctly?
So the question arises whether any currently produced turntable cartridge with a Micro Line / Shibata / SAS stylus tip cut will have a linear response throughout the entire range?Yes. However, slight peaking 10-20 kHz is less audible.
All stylii varies somewhat, so perfect is not really possible. But Ortofon Super OM30/OM40 and Nagaoka MP500 are quite good in the linear response game. Some AT MCs seem ok as well. With respect to currently produced cartridges there are also currently produced stylii (JICO SAS/B) that works well for certain vintage Shures (e.g. V15III, V15IV and V15-Vx).So the question arises whether any currently produced turntable cartridge with a Micro Line / Shibata / SAS stylus tip cut will have a linear response throughout the entire range?
Here's my Ortofon 2M Black. It's a nude Shibata. From what I recall, I think the STR understates the high end a bit, but still a pretty good response, so maybe a generalization about stylus tip is not valid?
That helped a bit, and was not difficult to do. I am fortunate also that I have the ability to change capacitance with my pre.It looks really decently linear, but you need to reduce the standard 47 kOhm to 32 kOhm,
Here's a Concorde 30 of the same era to compare. I don't have the special tonearm weight, so I had to tape a coin to the cartridge. Excuse the channel imbalance:Ortofon Concorde 20 First Version, probably around 1979.
My short answer would be that the rig, if set up properly, won’t really have an effect on freq response.
Yep, that’s how it is. Seeing is believing!The level and amplitude frequency of the unwanted resonance changes in the range up to 20 Hz, but it has no effect on the 20Hz-20Khz range. The frequency response of the turntable cartridge is identical.
Unbelievable, but that's how it is!
Just measure it with different turntable feet.As for the various ways of isolating the table, maybe it will lower distortion some? I don't know. Some people swear that updating the TT feet will tighten up the bass, and maybe it will, I’m not even sure what that means, but to me the feet are first and foremost about taking care of possible noise...
