aaaakkkk
- Joined
- Aug 22, 2023
- Messages
- 197
- Likes
- 160
Cart straight to APU? That R load would explain why the HF response is so abnormal.
Yeah. Could this explain the missing rise I see other people get at 10k before the fall?
I included another measurement of riaa disabled. So my cart seems seems abnormal? Any chance its test record?
ou're putting a 20k load on the cart. Your plot shows what one would expect from an inappropriate load. The APU is not a suitable MM preamp.
Info on these devices is a hot mess. From what I could find it seems the device needs to be modified for the 23.5/47k load, or perhaps it's also an order option. The Ali store is set to vacation so you can't even see it. The standard 10/20k probably works fine for MC.
Conductive@JP Do you recommend any particular headshell wires?
No its connected unbalanced RCA -> TS, I was waiting on my lcr meter to consider if it was worthwhile bypassing the 100pf output circuitry and to match my cable run. Thanks for all the help, I see where my problem lies. Both my apus are default stock so its most likely seeing a 10k load, now to source a proper phono preamp without riaa eq...
