That’s a boron pipe cantilever?
I believe it is - if it still has the original - diamond sputtered hollow boron pipe...That’s a boron pipe cantilever?
Depending on the test record, some of them (or some tracks?) are intended to be used without RIAA / EQ...I have some ..-45kHz. test record , QR2010 and ortofon.
do not look so good..tracks even on same record deviates
I may have an EQ calibration problem beyond 20khz... suspicious slope 20k-45k
Lovely! (F/R)Shure V15 Type V xMR with original Shure Beryllium stylus
This is running through my Yamaha CX-A5100 phono input, an 11.2 channel AV processor. I used the pre-out at +0 dB in Pure Direct Mode.
I am not the original owner of the turntable or cartridge.
Since this is the original beryllium stylus, it has to be stiff/worn. Nonetheless, this is a great result which really shows the "transparency" of the Shure V15 VxMR and at least the general quality of my CBS STR-100. This is used in my home theater room, so it's using a run-of-the-mill Yamaha AV processor which is officially graded as +/- 0.5 dB for RIAA accuracy.
- CBS STR-100 found off eBay. It has a lot of surface noise and pops even though it visually looks clean. Warping is easily seen in the recordings.
- Sony PS-X555ES Biotracer Linear Tracking Turntable
- 1.5 grams with the brush enabled (so ~1 gm actual tracking)
The channel imbalance is about 1 to 1.5 dB. That seems to be what someone else reported too!
Azimuth again! and Channel balance.- Vinyl Engine
www.vinylengine.com
Another really nice cartridge! - a good contender for digital EQ... - and this one will definitely take advantage of the biotracer...Vintage Grado XG Gold
- 1.5 grams
The V15V you could try without the brush down too - given you are running on a biotracer arm
Looks like total capacitance is bit high. 150-200 pF total is ideal.Ortofon 2M Red
This is being run with a Pro-Ject Debut Carbon DC running through the Kenwood L-08C. This was a sold as new-old stock. It was showroom cosmetic demo that was unlikely to have been run since the power adapter was missing.
In a way, this is a really impressive result for a budget cartridge. It's no wonder it's such a popular cartridge for value-priced turntables. The high frequency roll-off gives you the "warmth of vinyl" and it's surprisingly flat! Not shown here is that this had a lot more surface noise than the other setups I recorded.
- Pro-Ject Debut Carbon DC running through a Kenwood L-08C
- 18 mN (1.8 grams)
Yes I am quite fond of the Grado's - but neutrality ain't their thing!It is interesting that my most expensive "audiophile" setup had exceptional channel matching (the ZYX manufactured Monster Cable Sigma 2000 MC + Marantz PM-10). However, the Sigma was not that flat and had its own signature -- the Monster Cable "extra bass" sensation![]()
Here's a comparison normalizing them individually and picking the two most similar channels
On the Biotracer, I have actually run the Shure at 0.9gm and had excellent results. I use the brush in part because it picks up a lot of dust for me: )
What is neat is that the vintage Grado XG sounds great but you can see that it's giving you a smiley-face EQ automatically!
This is far from the best of Ortofon MM tech...Ortofon 2M Red
- 18 mN (1.8 grams)
Yeah, the Lowbeats measurement of the Red even showed a bit of lift at HF. My Blue measurement in this thread was flatter at ~190pF total. Distortion a bit better too, but not at HF.Looks like total capacitance is bit high. 150-200 pF total is ideal.
Which Shure V15?@GXAlan , great plots,Many thanks , It would be great to see the plot «1» to see channel separation also. . All you plots have quite high distortion -5db at 5-10k, I suspect that is from the CBS test record? Can anyone confirm this?
PS , please include Capacitance in the information, I am hoping to learn how my incoming Shure V15+ Jico Hyper elliptical should be loaded,
www.audiosciencereview.com
@GXAlan note also that you will want to undershoot your loading a little with the CBS test record as it really is about -0.5dB from around 5-15kHz more or less. This is important if you are using the test record to set up your system. And joining the others, please provide capacitance information and crosstalk measurements as well. And the consistent -30dB 2nd harmonic at 1kHz in these new ones is odd and you may want to investigate that as it doesn't appear to be the limit in your earlier measurements. Other than that those are great adds to the library and I'll add them to the index. Thanks! Please see these measurements and others on the script thread for more information on the FR differences between the test records.
Introducing the Phono Cartridge Measurement Library
Skip to the index. After years of development we are finally launching our phono cartridge measurement library. These measurements were created using the brilliant cartridge response python script, SJPlot, written by the legendary @scott wurcer and @JP. Information about its origins can be...www.audiosciencereview.com
