Balle Clorin
- Joined
- Dec 26, 2017
- Messages
- 2,696
- Likes
- 2,347
The seller giving me a carefully checked replacement, so I am happy
How do you cope with having to setup the lot of them perfectly before making a final measurement with high confidence? Asking for a friend...![]()
I am finding it hard to resist the urge to buy an Empire 4000 D/III. Hopefully someone here already has one.
MP-110
Notes
- Cartridge: Nagaoka MP-110
- Stylus condition <50hrs on vinyl
- Test record: CBS STR100 issue 3
- Turntable: Fluance RT82 Stock
- Tracking force: 1.85g
- Phono stage: Schiit Mani 2
- Capacitance- Unknown, likely around 210pF
- Rip kindly provided by a friend who I sent the record to
Is there any way to make the distortion scale manually adjustable, or limit it to reasonable limits. for example 60 dB. ?Worst thing I ever did was to add crosstalk to the plot.
axtwin.set_ylim(-60,5)
I absolutely understand whyWorst thing I ever did was to add crosstalk to the plot.
An amazing result for the STR-100. I wonder what the real SRA of this JICO SAS is.Technics EPC-205C-IIL Jico SAS Boron
This one was a little loose fitting to the cartridge body, so a bit of Blu-Tack was used to keep it snug.
interesting. would some extra capacitance help with that dip?
At least part of the difference is due to some degree of dip inherent to the STR-100 record, from what I understand.View attachment 341519Interesting difference , does not like mine at all..I will try a different RIAA with lower capacitance
I think the angle of the cantilever is already determined by the cartridge (the shank of the stylus assembly fitted into the cartridge is already fixed). An aluminum stylus has a flat end which will cause a difference angle from stylus tip to pivot compared to a sold boron stylus that is straight to the end of the stylus. Would be interesting if you measured the other stylus as well (both cantilever and tip to pivot), when you get a new one ( the one you showed had a sagged suspension). If the stylus angle is the same, it is the tip to pivot that is changed (due to different cantilevers).The SRA if my Jico is correct but The VTA of the SAS B for my Shure V15 IV is 30 degrees and gives uneccessary 2% intermodulation distortion when a proper angle would give <0,5% . Why Jico does this I do not understand. I will never by a Jico SAS again, the answer I get when I ask Jico about this is nonsense….
Post in thread 'Introducing the Phono Cartridge Measurement Library'
https://audiosciencereview.com/foru...tridge-measurement-library.46108/post-1830454
