Balle Clorin
- Joined
- Dec 26, 2017
- Messages
- 2,691
- Likes
- 2,342
I get
I use get SRA 85 about, more VTA makes it worseSRA = 80, is it possible?
Can try but, More VTF makes right channel drop more above 10k, track 70um on Ortofon record, slight buzz in both channels at 80um@Balle Clorin
Re VTA: Make sure your SRA is correct first. 1 g VTF might be to little, suspension compression is too light. Range is 1.0-1.5 g. Suspension might change after a few hours play also.
SRA seems around 94°. Adjust VTF up and check again.
If you mean -5 degree (which I denote 95°), then it is a bit too much IMO. -2 degree (92°) is a target. I think it is better to adjust for minimum distortion in the high frequencies.I get
My JICO tracks 100 µm on the Ortofon record (1.4 g, brush down (with added oil to hinges)).Can try but, More VTF makes right channel drop more above 10k, track 70um on Ortofon record, slight buzz in both channels at 80um
I was just about to suggest the same thing. A short list of recommended or +-0.5db cartridges would be amazing.This thread is so great but it's a bit time consuming to go through all the individual posts to find out which ones are the top performing carts. Has anyone extracted a top 5 list yet?
HYPEREL 6445 VTA,SRAIf you mean -5 degree (which I denote 95°), then it is a bit too much IMO. -2 degree (92°) is a target. I think it is better to adjust for minimum distortion in the high frequencies.
Yes, I misunderstood. That stylus is faulty/ broken.
Very nice. In this case you might need 60k. How does it sound?
Low distortion. Reminds me I need a new JICO SAS.
drive.google.com
drive.google.com
The PTG looks like it has a problem with undamped resonance - it is in a relatively "safe" place - but still, probably could get some benefit from an arm with fluid damping (or equivalent) - The highs reflect a cantilever resonance which cannot be compensated for without digital EQ (would be nice if the effective tip mass were lower... then the peak wouldn't be there!)V15-IV JICO SAS-B ON SONY PS-212 DD TT. 1.5gram brush down.
SONY V15-IVSASBBRUSH WATER OF LOVE LEVEL ADJ.wav
drive.google.com
AT33PTGII ON SME V MICHELL GYRO SE
AT33-PTG2 DIRE STRAITS WATER OF LOVE Ladj.wav
drive.google.com
Files are level matched as good as I could. Here is PN comparison for cartridge
F/R change or phase change?(edited)
I have a vintage Sony MC that has almost the exact same profile as the PTG you are showing there - and it has a certain "sweetness" of tone, that is quite attractive on many records... a bell like clarity, which can be lovely.... when I experimented with digital EQ to match its F/R to a flat profile, the sweetness evaporated.... and it then sounded identical to similarly adjusted Shure/SAS, Ortofon OM30, AT440MLz and others from my collection.
Frequency Response ...F/R change or phase change?
(the loss of sweetness)
Or something else ?
The SAS is nicely tuned in there - you could perhaps fine tune it a dab more - but the result wouldn't be substantial (and probably not audible)
I'm not convinced that we understand exactly what the Puffin is doing to the signal... the Cambridge is a traditional phono stage - we know what is happening there.Hm, I have a bit difficulties to understand the loading result of the Cambridge vs the Puffin. Usually higher capacitance moves the peak to lower fr, and makes drop at lower f too. Below with pink noise.
ive done a couple comparison plots of left channels of carts comparing the puffin to standard pres and i havent noticed anything out of the ordinary or unexpected with regard to frequency response. .I'm not convinced that we understand exactly what the Puffin is doing to the signal... the Cambridge is a traditional phono stage - we know what is happening there.
Very nice seletion!!
How do you cope with having to setup the lot of them perfectly before making a final measurement with high confidence? Asking for a friend...
