Unfortunately, my tonearm does not have azimuth adjustment.Nice , thanks.interesting alignment effect. How does it look without common normalisation at 1khZ, Current setting hides any channel imbalance..
It may need som azimuth adjustment, large crosstalk difference.
One can use angled shims.Unfortunately, my tonearm does not have azimuth adjustment.
Channels are within 0.4 dB at 1 kHz.Nice , thanks.interesting alignment effect. How does it look without common normalisation at 1khZ, Current setting hides any channel imbalance..
My trick: If you have a tonearm with a standard headshell, twist slightly the headshell to the right (or to the left) while inserting and tightening it into the arm wand, measure, repeat. It is easy to overshoot, multiple measurements are usually needed till you get it right.Unfortunately, my tonearm does not have azimuth adjustment.
fricc, I appreciate your help but unfortunately my Rega RB300 tonearm has not a standard headshell, it is in one piece with the tonearm.My trick: If you have a tonearm with a standard headshell, twist slightly the headshell to the right (or to the left) while inserting and tightening it into the arm wand, measure, repeat. It is easy to overshoot, multiple measurements are usually needed till you get it right.
Given the tolerances of the typical headshell mount (I have a Technics SL-1300G, it is very lose), this is as good as it gets...
Thomas, are you selling them?One can use angled shims.
https://www.audiosciencereview.com/...inyl-measurements.20278/page-134#post-2546378
Yes.Thomas, are you selling them?
Fascinating. When I first started buying cartridges, electret seemed to be classed as low-end, suitable only for cheap "music centres". If you were willing to spend "real money", MM, MI and MC seem to have been classed as higher quality. Now I'm confused!Micro-Acoustics 530-mp
This is a very interesting cartridge, it features an Electret (piezoelectric) transducer, no coils, no magnets.
The output impedance is purely resistive and it is completely load insensitive. An internal passive output equalizer stage makes it RIAA compliant.
More info in the Micro-Acoustics 1977 Catalogue, the MA 530-mp was the top of the line at the time with a beryllium cantilever and a Micro-Point stylus.
I just bought this as NOS for $550 on US Audio Mart. Looks like a winner
View attachment 569023View attachment 569024
Electret and piezoelectric aren't the same. Electret is variable capacitance with a fixed charge, usually varying the air gap between the plates. With piezoelectric the deformation of a solid produces a change in charge.This is a very interesting cartridge, it features an Electret (piezoelectric) transducer, no coils, no magnets.
Micro-Acoustics cartridges technically use a piezoelectric ceramic element (lead-zirconium titanate), though the company marketed them using the term electret.Electret and piezoelectric aren't the same. Electret is variable capacitance with a fixed charge, usually varying the air gap between the plates. With piezoelectric the deformation of a solid produces a change in charge.
The roots of the company were into old school ceramic cartridges, but they were also they were industry leaders in cutting heads for making records.Fascinating. When I first started buying cartridges, electret seemed to be classed as low-end, suitable only for cheap "music centres". If you were willing to spend "real money", MM, MI and MC seem to have been classed as higher quality. Now I'm confused!
Seems like misleading marketing to avoid the poor reputation of ceramic (piezoelectric) cartridges, using a term associated with microphones.Micro-Acoustics cartridges technically use a piezoelectric ceramic element (lead-zirconium titanate), though the company marketed them using the term electret.
There is some history here: Micro-Acoustics Corporation History Page.
I don't know about "misleading marketing", they had a real good piece of technology, and they had to go for a different bucket than the cheap piezoelectric carts of the past.Seems like misleading marketing to avoid the poor reputation of ceramic (piezoelectric) cartridges, using a term associated with microphones.
