Introducing the Phono Cartridge Measurement Library
Take a look at the CA-TRS-1007 vs JVC TRS-1007 vs CBS STR-120 test records. CA-TRS-1007 measure +6dB (above 10K) compared to TRS-1007 and STR-120. I purchased my TRS-1007 new imported from Germany, the other test records are purchased used.
Or you may see this as STR-120 is +2dB (above 10K) vs the other +4dB (above 10k). How do you see it?
Nagaoka MP-150 cartridge.
Did you mean JVC trs-1005? Not JVC 1007? The fundamental level difference seems to be max 2db not 6. crosstalk vary a lot between records, hard to say which is correct
Nice channel balance..
Nice to see. If you lower C to below 200 you will probably get more linear response. However, keep experimentation to some other thread though like ”test records” or ”fun with vinyl measurements”. This is mostly dedicated to cartridge evaluation.
Correct, JVC 1007. What I typed was a typo.
OK, got it on the test records thread. I started with a low C below 200 which did give me a linear response up to ~5kHz then it would peak at 15kHz then roll-off.
Audio Technica ART9xa (the title on the graph is wrong) with maybe 75 hours. I had suspected this cart had issues so I sent it back to Audio Technica. They "cleaned" it after discovering a small metal shard in the motor assembly, "tested" it and "verified" that it met specs. What I got back was almost identical to what I sent them. This still looks pretty bad to my eyes with too much channel imbalance for my tastes. The measurement was taken through a Focusrite 2i2 USB interface, balanced XLR connection direct from the cartridge, with the RIAA compensation performed in the measurement script. New copy of CBS STR-100. The turntable is a MoFi MasterDeck at 1.8g. Loading changes didn't produce any significant differences in performance here. That weird glitch on the left channel at around 12kHz shows up in every measurement.
I have a Hana Umami Blue on order which will replace this cart and it should arrive this Thursday. Will do some measurements on that one and of course post them.
Good move away from Audio Technica to Hana. I challenge someone to post a "good" channel matched Audio Technica cartridge. My new copy of a CBS STR-100 didn't give me good results, I switch to CA TRS-1005 or STR-120 (both hard to find). For the price of the cartridge, I'd expect much better measurements. Speculating here, Audio Technica has an out of spec (uncalibrated) test instrument in use at their test lab/factory and were getting the spoils.
I occasionally use pink noise to test for frequency response, and monitoring the output on an RTA gives real-time visual feedback for adjustments. On these RTA plots, the same basic channel mismatch problems show up as on the sweeps.
Left Channel:
Right Channel:
Audio Technica ART9xi with maybe 75 hours. I had suspected this cart had issues so I sent it back to Audio Technica. They "cleaned" it after discovering a small metal shard in the motor assembly, "tested" it and "verified" that it met specs. What I got back was almost identical to what I sent them. This still looks pretty bad to my eyes with too much channel imbalance for my tastes. The measurement was taken through a Focusrite 2i2 USB interface, balanced XLR connection direct from the cartridge, with the RIAA compensation performed in the measurement script. New copy of CBS STR-100. The turntable is a MoFi MasterDeck at 1.8g. Loading changes didn't produce any significant differences in performance here. That weird glitch on the left channel at around 12kHz shows up in every measurement.
It would be interesting to see ATs measurements, with their claimed within 0.5 dB channel balance.
I see 0.75 dB. Not unusual for many cartridges, but I would expect better for the price.
More to the point, the stereo imaging when I'm playing vinyl is audibly shifted to the left by the imbalance. My listening room is highly symmetrical and the shift is clearly audible even if it's "only" 0.75dB at 1kHz. I too really expect better for the price.
I agree. AT, or any other manufacturer, should check their process and include measurements with each unit of expensive cartridges.
AT used to, my OC9MLii came with a print out, with actual ink. Every RIAA/preamp need a balance control for vinyl….in they do not have it , it is bad design decision.
I agree about the balance control which why the preamp I use, which I designed, has both balance trim and trimmers for the RIAA eq.
The last cart which I had which came with a genuine, original response printout was a Micro Acoustics 630 (?) I had long ago. Some others I've had came with a printout for response but it was merely a copy of one example's response and not an original plot for the actual one I bought.
The Denon DL103 series still come with individual ones. Both my R and plain jane ones came with them. It only shows one channel's response (doesn't say which, done with JVC-TRS-1005) but both channel levels at 1 kHz.
Hana Umami Blue
This plot is unloaded straight into the USB interface (Focusrite Scarlett 2i2) so that there were no influences or variables to alter the response. I took measurements through my phono preamp which is 250pF/120 Ohm with identical results. The turntable was a MoFi Master Deck and the tracking force was 2.0g and the test record was CBS STR-100.
That's one hot top end! :eek:
I'm going to be sending this back and going to try a Dynavector XX-2A which although it also has an elevated top end, it isn't nearly as bad as this Hana Umami Blue which is just to exaggerated for my tastes. It's nice and flat up to the point where it goes ballistic though. :facepalm:
Hana Umami Blue
You should use the proper loading before posting, and post that
HUH? I did go into detail about the loading (250pF/120 Ohm) and I also tested it through a 1:20 Cinemag CM-20724 SUT (which multiplies the capacitance of the phono preamp by 400X of course). I also tested it both direct into an interface and into a proper, loaded phono preamp and both plots were identical - what is posted is the direct-to-interface condition as noted on the plot. If there's something missing, I sure fail to see what - maybe you should read more carefully?. The plot is the realistic performance of this cartridge, and it obviously isn't terribly dependent on the loading used or not used. If differences cropped up, I would have posted details about those differences. At some point if all the conclusions point in one direction, we have to assume the data are correct and move on.
