melloncolliecat
- Joined
- Jul 31, 2023
- Messages
- 116
- Likes
- 52
This sounds strange to me. I've had a ton of overlapping Stanton 880/980 and Pickering XSV/XUV models and they've all fitted perfectly. The XUV 4500 is much lower in inductance, so with a Stanton D81 stylus the high freq peak is higher (kind of like my measurement with the LP Gear Vivid Line in this thread, but not as high a peak), but otherwise they all seem to work perfectly fine with each other.Bonus fact: The XSV 3000 and the Stanton 881s are NOT electrically and mechanically compatible. I tried using the D81s stylus from the 881s on the XSV 3000 body: it fit snugly, but HF response was not flat and it had much higher distortion than the Stanton. I also inserted the stylus from the XSV 3000 on the 881s body, the fit was very loose and it would wiggle around. I don't think it is a good idea to mix and match.
If I can muster up the energy I'll try to measure one or two.
And oh, sorry, great to see your measurements of these classics here! Thanks for that!
