Introducing the Phono Cartridge Measurement Library
Audio-Technica VM 750xSH
A new measurement using the Blue Jeans phono cables, rated 12pf/ft x 3ft = 36pf. The Pre impedance is 100pf/47kOhm. I have also properly equalized the channels levels.
No noticeable change in the frequency response. Azimuth verified with the HIFI News record. I also tried different VTA angles: this cart seems quite immune to that.
Same setup with the stock Technics phono cable (~150pf):
It does come down by ~3dB at 10kHz, but now the upper midrange sags.
This is an intentionally BRIGHT cartridge. Nothing else I own is anywhere as bright as this guy.
Candidate for return.
I measured BJC LC-1 x 3 ft at 45 pF and LC-2 x 3 ft at 41 pF. There's a few pF for the connectors.
I know it makes no practical difference!
And the Technics current phono cable 90 pF.
Oh, thanks for your measurements, the only quoted impedance I found online for the Technics cable was 150pf.
This explains why the BJ cable only modestly alters the frequency response.
Just realized that all of my recent measurements mistakenly say "miniDSP ADept -> Focusrite 2i2" :facepalm:
When using the ADept, I don't use the Focusrite, of course :)
Most of the Denon MC's do have high distortion, right?
Some are higher than modern MC's, yes, mainly in the high frequencies.
But you'll see in the measurement I quoted that another example hit -30 at 5k and -20 at 10k, whereas mine is -24 at 5k and -18 at 10k.
I'd be surprised if it didn't have at least a moderate amount of wear. I definitely noticed some obvious distortion in louder passages.
Did you shim VTA?
Not too much different with VTA shimmed 6º. Better crosstalk (though that can also be azimuth variation):
Shure V15 Type IV #2 JICO SAS B #2 Outer 1.5 g ~130 pF 50k Ω CA-TRS-1007 #2 - Side B norm1 1 0...png
Ortofon Concorde Digital MKII
Stylus is completely new, never used before the tests.
Notes:
- I have measured the cartridge on the Reloop and also my AT-LP120x, both in excellent condition.
- The high frequency peaking ,and the resonance before 500hz are both worse on the AT, I suspect that the arm on the AT is too heavy for the cartridge
- I have tried changing Phono cables, multiple setup variations of tracking force and anti-skating, and measured the cartridge through my Pioneer mixer with built in phono stage, all showed the same results.
The 20Hz peaking/resonance seems to be the worst on this model. Funny that Ortofon specs this at 20hz to 18khz, yet all three Concorde have similar extensions in the treble, with this being the flattest of the bunch.
Made a mistake, and I cannot seem to edit the post now. Capacitance is the capacitance of the Preamp as per the manufacturer; I cannot measure the total capacitance of the setup, but I did try cables of different lengths for all the measurements, with no measurable effect.
Ortofon Concorde Club MKII
Notes:
- The high frequency peaking ,the resonance before 500hz, and the rise around 20hz are all worse on the AT, I suspect that the arm on the AT is too heavy for the cartridge
I have also measured the Ortofon Music Red and Ortofon Digital variants of this Concorde style cartridge. Both show similar issues, with the Club being worse than the Red, and the Digital is somewhere in between.
After extensive testing the only thing I can conclude is that there are serious issues with this design or I am the unluckiest person alive! :D
Ortofon Concorde Music RedView attachment 553527
Stylus has around 40 hours of play.
Notes:
- The high frequency peaking ,the resonance before 500hz, and the rise around 20hz are all worse on the AT, Ortofon lists that turntable as compatible, but not the Reloop.
I have also measured the Ortofon Club and Ortofon Digital variants of this Concorde style cartridge. Both show similar issues. At this point my conclusion is that there is something wrong with this Concorde style form factor which is causing the inaccuracies. The Concorde Bronze measurements available here on ASR show similar results.
If someone has a suggestion of what could be tried to improve the results I would like to hear it!
Sony XL-88D
Sony XL-55 II
I bought this as NOS, though it wasn't sealed. The photos conveniently did not show the cantilever clearly, which is misaligned with the body.
I can't tell if it's age-related or if the entire magnet assembly was installed crooked, as the visible magnet underneath the cartridge does look to be tilted the same way.
I aligned to the cantilever:
Sony XL-55 II Outer 1.5 g ~1 nF 100 Ω JVC TRS-1007 #2 - Side A norm1 1 08-22-26.png
Sony XL-55 II Outer 1.5 g ~1 nF 100 Ω JVC TRS-1007 #2 - Side A norm0 1 08-22-26.png
The frequency response is very similar to JP's quoted measurement of the XL-88D.
I'm not quite sure exactly what Sony was going for with this, as their earlier designs seem much flatter.
VM95ML stylus with an AT-XP cartridge - TRS-1007 test record
Wanted to share this one, looked interesting, I like this iteration in terms of sound.
Notes:
- Phono preamp input is 150pF, cannot tell you the total of the setup
- Phono preamp 47kOhm, same as above
Audio-Technica AT-VM95C - JVC TRS-1007
This is a VMN95C stylus on a VM95ML body. Cartridge is likely a bit tail-up.
130 pF:
AT-VM95C Outer 2.0 g ~130 pF 50k Ω JVC TRS-1007 #2 - Side A norm1 1 08-29-26.png
260 pF:
AT-VM95C Outer 2.0 g ~260 pF 50k Ω JVC TRS-1007 #2 - Side A norm1 1 08-29-26.png
410 pF:
AT-VM95C Outer 2.0 g ~410 pF 50k Ω JVC TRS-1007 #2 - Side A norm1 1 08-29-26.png
80 pF and 100k ohms:
AT-VM95C Outer 2.0 g ~80 pF 100k Ω JVC TRS-1007 #2 - Side A norm1 1 08-29-26.png
View attachment 555270Wanted to share this one, looked interesting, I like this iteration in terms of sound.
Notes:
Something looks wrong with your 2nd and 3rd harmonic distortion - they roll off at way too low a frequency. It looks like you are only sampling at 44kHz. You need to sample at 96kHz to see the full high frequency cartridge behaviour.
You are right, will redo the measurements.
Audio Technica VM 750xSH vs Shure V15 V MR, on a Technics SL-1300G, best alignment results I managed.
The 40+yo vintage Shure is more linear, has better separation, and a bit more HF distortion. In listening they're hard to tell apart though.
I've been looking for a suitable replacement for the aging V15 V, the VM 750xSH comes close enough :-)
Nice! But what is the result at standard load 47k and some normal/practical pF say 220?
At normal load AT cartridges have a very pronounced HF rise. I have posted some results earlier in this thread. Fortunately the miniDSP ADept has a range of configurations for load adaptation.
Just to clear things up, I will only add measurements to the library if the first measurement is of a "normal load." Esoteric loads, while lovely to see as supplementary measurements, are not useful for the purposes of this project (edit: as the only measurement for a cartridge, an important distinction I believe) and do not give us a view of the cartridge's "historic performance." We want this to also be an archive of the medium in a certain sense. Certainly EQ has today made "perfect loading" (lol) even easier to achieve.
I'm hoping to update the library in the coming weeks, but, man, did you guys add work this last week.
