You can probably get it more linear with higher capacitance and lower RI just bought this cartridge. It's strange that the same stylus with a Shure M111E body has a higher peak than with an RXP3 body. I'll have to measure the cartridges' inductance. I use the Waxwing as a line-in DSP with a Tag McLaren PPA20, so I'll try to correct the peak on the Waxwing as a last resort. Do you think I have a capacitance problem or something else?
I have a McLaren PPA20 and a Waxwing DSP connected to it in line-in mode. Do you think it would be better to adjust the graph by C and R on the PPA20, or use the DSP in the Waxwing? If you could explain why I'd be grateful. Thank you and best regards.You can probably get it more linear with higher capacitance and lower R
If you have the waxwing you can fix most of it there. With the PPA20 you would need loading plugs.I have a McLaren PPA20 and a Waxwing DSP connected to it in line-in mode. Do you think it would be better to adjust the graph by C and R on the PPA20, or use the DSP in the Waxwing? If you could explain why I'd be grateful. Thank you and best regards.
Thank You, i have loading plugs to connect them to RCA inputs. My questions is: which way is better and why ?If you have the waxwing you can fix most of it there. With the PPA20 you would need loading plugs.
EQ is more flexible; loading has limits what it can do. So in practice EQ is better option.Thank You, i have loading plugs to connect them to RCA inputs. My questions is: which way is better and why ?
Shimmed or new stylus?Shure V15 Type IV with JICO SAS/B - JVC TRS-1007
I really think this is the best value out there today in terms of price and performance, assuming you can find the necessary cartridge body.
Very flat, very low distortion, and excellent crosstalka great sounding cartridge!
Neither, I haven’t had a chance to play around with that yetShimmed or new stylus?
Ok, the response was a little different from your previous measurement.Neither, I haven’t had a chance to play around with that yet
Oh, this measurement was taken using the original JVC TRS-1007 that I recently acquired.Ok, the response was a little different from your previous measurement.
Ah ok. Interesting to note the difference in crosstalk. Start to think that the CA TRS1007 is an odd one.Oh, this measurement was taken using the original JVC TRS-1007 that I recently acquired.
I also increased the capacitance.
L 1347 Ohm 620 mH
L 1384 Ohm 640 mH
Got to say I'd have expected better from an elliptical tip. Current huge-priced 10XVs now have Shibata diamonds fitted I believe, so the end of side responses should be better.Dynavector DV-10X5
I think this one looks pretty worn. Thoughts?
View attachment 540072View attachment 540071
