Introducing the Phono Cartridge Measurement Library
This is very, very, very bad. Significant drop in frequency response, very significant crosstalk problems.
Shure V15 IV + JICO HE stylus
This stylus was reported to have approximately 113 hours of play time.
Distortion is higher than I expected. Crosstalk on the inner track is interesting where those two blips appear. I wonder what's causing that.
I thought there was another non-SAS HE measurement on here, but I can't find it.
Shure V15 Type IV #2 JICO HE Outer_1.5 g_~200 pF_47k Ω_CA-TRS-1007 #2 - Side B_norm1_1_03-17-26.png
Shure V15 Type IV #2 JICO HE Inner_1.5 g_~200 pF_47k Ω_CA-TRS-1007 #2 - Side B_norm1_1_03-17-26.png
View attachment 518554View attachment 518553
i think @Balle Clorin had a tonar he? id really like to see one of these under the scope. i dont think jico publishes the tip dimensions for the hyper ellipticals.
There's a major problem with crosstalk between channels. Your stylus setting is wrong, or your stylus is bad.
First, set the azimuth correctly.
On a Technics turntable with a standard headshell, getting the azimuth correct is a pain: minimal adjustments, measurement, minimal adjustments, measurement. After 6-8 tries, it's finally set correctly :)
The azimuth adjustment on this turntable is a rubbish solution :( It's a technically outdated design, very imprecise. The manufacturer should be ashamed of offering something like this in the 21st century. :(
Measure it another record and you get a different result.
If the stylus isn't faulty, worn, or in poor condition, it can usually be adjusted to achieve equal crosstalk between the channels. However, this requires numerous tests and measurements, and is very tedious and time-consuming.
Yes for one record only. And need to include VTA as well.
An average.
What are we talking about?
Are we talking about crosstalk values at 1 kHz/15 kHz, or about ensuring that the crosstalk between channels is the same across the widest possible frequency range?
If we're talking about ensuring that it's the same, then the cartridge simply needs to be positioned correctly.
Shure V15 type III with Jico VN35HE stylus
Here's a result from a new Jico hyper-elliptical stylus for the Shure V15 type III cartridge. Distortion levels look decent to me, but this is using a CBS STR-100 test record, so it's not an apples-to-apples comparison to the other stylus (which is also for a type IV cartridge). Take it for what it's worth.
I don't have a microscope to photograph the stylus tip, but if someone can recommend a good one that's not too expensive, I'd consider buying one.
Shure V15 Type III with Jico HE stylus  | 1.5 g VTF | 47kΩ 325pF | CBS STR-100.png
I bought one of these, mostly to check on stylus wear. Works just fine for that and you can take pictures. https://www.amazon.com/dp/B08G4Y6C65?ref_=ppx_hzsearch_conn_dt_b_fed_asin_title_1&th=1
I picked up a microscope and took some photos of the Jico V35HE stylus. I'm still learning how to use it, so apologies if the images aren't great. All I can tell for sure is that it's a bonded stylus.
JICO does not list that what I can see, so this is a previous model?
This is the model. I ordered it from Amazon, not Jico. I don't see a hyperelliptical model on Jico's website right now. I think they make certain models for US export that they don't sell from their Japanese webshop. I know they also make models specifically for the Canadian market. Curiously, this model has "Jico jp" (not US as pictured on the listing) imprinted on the brass insert, indicating it was not made for export. Maybe it is an older model; it's hard to say. It gets confusing.
That stylus shown in the picture is a SAS/S.
