So now with the latest Windows update I can finally try this out for real! ^^ Just had to do some soldering on these cheap PCM5102 boards, apparently some (mislabeled!) jumpers needed to be bridged before they could accept the I2S input.
Anyways, they seem to sound just fine and the software is mostly doing what it's supposed to be doing except for the loudness compensation that goes hard clipping on the master channel as soon as I enable it?
As I understand it it should be compensating upping the bass, but seeing that it does it by around 20dB which just clips everything I'm not sure if it does it correctly? Or should I compensate it by lowering the preamp by around the same amount? Looking at the loudness graph in that window it looks like it's supposed to lower the midrange/treble and not upping anything. Could the be clarified maybe?
Also what exactly is the reference SPL supposed to be calibrated against? Is this whatever SPL at 1kHz comes out from my speakers with the host volume set to max?
I've done some testing (without any actual SPL measuring) and no matter the reference SPL I cannot get it to have the FR to sound the same when I change the volume, instead I have to set it to 100dB and then lower the intensity to 30% to get it to sound more or less the same (a bit more upper bass muddy at lower volumes though) when I change the volume. Feels like this is the wrong way to do it? Though I guess if it works it works, I really do like having this which is one of the reasons why I want DSPi instead of my MiniDSP, but it would be nice to have it set up correctly instead of just guessing
Btw, the icon for the loudness compensation and the volume leveller seems to be flipped, so the loudness has a moon and leveler has just a normal speaker icon.
Would also be nice if we could somehow get the loudness compensation showing live in the filter response somehow.
Can we get a left/right channel linking option for at least the master EQ? I don't know how other people use the master, but I tend to do my final subjective curve there and that should be the same on both channels so linking would be nice.
The filters seem to have a comma showing no matter what, mostly cosmetic I guess but it shouldn't probably be like that. Would also be nice to be able to be in on field and then tab to the next one.
And lastly, when DSPiConsole is opened the window is quite small, filling just a small portion of my screen with everything cramped together in there. The loudness window does the same. Could these be at least twice as big, or at least have the size saved in a config somewhere?
Anyways, fun stuff to finally be able to play around with it myself and maybe contribute a bit for this awesome development
Thank you Troy!
