What kind of board do one need for SPDIF input?SPDIF input is now fully functional and stable. There remains some work to do with the PIO divider servo to maximize acceptance of the clock by SPDIF devices but expect a beta soon!
All that is needed are either a couple of resistors and a capacitor or a TOSLINK RX module.What kind of board do one need for SPDIF input?
Ah so one of those that have been linked in the thread before as outputs would do?All that is needed are either a couple of resistors and a capacitor or a TOSLINK RX module.
Yes, make sure your buying a receiver if using toslink. Transmitter for toslink out.Ah so one of those that have been linked in the thread before as outputs would do?
TOSLINK modules are available in input and output types. They’re unidirectional (LED vs. photodiode), so it is important to choose the correct part.Ah so one of those that have been linked in the thread before as outputs would do?
I am mostly clueless about the specifics to correctly wire these inputs/outputs.All that is needed are either a couple of resistors and a capacitor or a TOSLINK RX module.
Hi Troy, Is the windows i2s release looking likely today. Can't wait to test.SPDIF input is now fully functional and stable. There remains some work to do with the PIO divider servo to maximize acceptance of the clock by SPDIF devices but expect a beta soon!
For toslink the resistor values are dependant on whether you use 3.3v or 5v.I am mostly clueless about the specifics to correctly wire these inputs/outputs.
I tried to collect the information about that here in the thread. (from @Kingsnake and @Wesseling Audio Lab)
I asked AI and got something about creating a mid rail DC bias, but @Weeb Labs remarks made me try a (much) simpler approach.
Can someone please check and advise what might be wrong, please.
I will correct and we might have all the wiring info in one place. Or you might just do better
What is the correct input resistor for SPDIF input?
I found this, is it the correct way? Is it 100% needed or is it more like a "just in case" (I'm asking since it's not an easy thing finding single ones of those around here)?For toslink the resistor values are dependant on whether you use 3.3v or 5v.
68ohm is better for 3.3v. I used 5v and 220ohm resistor.
For the toslink receiver I did add two capacitors between vcc and gnd. Not tested yet though.
0.1 µF (100 nF)
handles high-frequency noise
fast cleanup
10 µF
handles low-frequency / supply dips
slow backup
Yes. The Windows feature parity update is coming this evening. Once that has been pushed, I will be making slight refinements to the current Firmware v1.1.3-Beta4 and pushing it as a final non-beta release.Hi Troy, Is the windows i2s release looking likely today. Can't wait to test.
Just added a toslink receiver to my little custom board too and rotary encode ready
Bidirectional USB audio is possible but introduces significant complexity, so I'm afraid it will have to wait until some of the more essential functionality has been implemented.Will it be doable to integrate routing from spdif in to usb, to use the unit as bidirectional recording device?
What USB Host were you planning to plug DSPi into? Can you expand on the "bidirectional recording"?Will it be doable to integrate routing from spdif in to usb, to use the unit as bidirectional recording device?
So USB plugged into Android as host, with the SPDIF connecting to Windows, how? And bidirectional recording as in either host can record from the other??I was hoping to be able the device as a tiny spdif IO audio device for use in windows and android to do multitrack recording
