Wesseling Audio Lab
- Joined
- Sep 12, 2023
- Messages
- 227
- Likes
- 201
It can be used standalone, ie, plugged into phone, ipad, streaming device etc. Connects as a usb soundcard.
In theory this could, one day, be used without USB with a 1.8 - 5.5 V input delivered to the correct pin on the Pico (even potentially a lithium battery input). But as of today, using the current 1.10 firmware, there is no option for audio input other than USB.Latency is discussed earlier in the thread.
"so it has to be a soundcard...?" I have the same question and for now using it in the most basic USB form.
Can the board be powered with separate PSU then have all future peripheral inputs and outputs functioning along with data only lines from USB?
I had success with the first one (yellow board) in this list (https://github.com/pschatzmann/ardu...02-i2s-iis-lossless-digital-audio-dac-decoder). Most of these devices seem to be compatible as well.Unfortunately, it doesn't work for a 4-pin I2S input, which is very common.
Most people including me will use this to introduce a sub out with crossover and delay setting without going down the AVR route or buying an expensive DSP. I like to take the lows off my main speakers.So if I have a good audio interface and a good software eq I don't need this? I thought the clever thing was to use it standalone?
Under hardware I forgot to include the frying the transmitter due to incorrect connection. It's part of the user error case.I got this wrong too, I used a google search and a generic pin layout instead of using the data sheet, I presumed they would all be the same. The LED was barley visible after correcting the pins, I was getting no output. tried 3.3v and 5v when corrected but I think I fried the LED.
This is entirely possible. At the moment, I am working on 24-bit SPDIF output and squashing various minor bugs. Once that is in place, SPDIF input is next.Would it be feasible to:
In other words, operate DSPi as a standalone digital processor with USB used purely for parameter control, while audio input is exclusively from S/PDIF.
- Disable USB as an audio source entirely (retain it only for configuration and control),
- Implement S/PDIF inputs via external receiver IC outputting I²S
- Add source switching between multiple S/PDIF inputs,
- Run the DSPI and S/PDIF output clocked from the selected input’s recovered clock?
If the system is clocked from the selected S/PDIF input and USB audio is not active, would this eliminate the need for ASRC, since only a single clock domain would exist at any given time?
Do you have a series capacitor on PDM output? That sounds like one of your subwoofers is not AC coupled and is being fed the DC offset from the PDM output.Spent today playing around with the Pico 2 and decided to recycle the rear panel from an old CCC DAC that had been doing absolutely nothing.
I repurposed the connections like this:
It actually worked out really tidy and looks factory once it is all bolted together.
- Old coax S/PDIF RCA is now the sub out
- TOSLINK is now the stereo out
- USB Type-B 2.0 is now the PC input
For the sub output I used:
Signal goes through the 1 kΩ to the RCA centre pin, and the 100 nF cap is from centre to ground at the socket.
- 1 kΩ resistor in series
- 100 nF capacitor to ground
I tested it on two subs:
The XXLS400 was not happy at all. The output was super quiet. When I tried turning up the gain on the sub it would give a small thump and basically reset itself. I tried reducing the pre-gain as well but it made no difference, it just did not like something about the signal coming from this setup.
- BK XXLS400
- DALI SUB E-12 F
I am guessing the 100 nF cap and the input stage on the BK just did not get along. With the 1 kΩ and 100 nF on the output, I had effectively altered the signal slightly, and it seems the BK did not like it. It felt like either the low end was being reduced more than expected or the input was seeing something it did not like when the level increased, so it tripped protection.
Swapped it over to the DALI and it was perfect straight away. Proper level, no thumps, no resets, behaved exactly how it should.
So same wiring, same 1 kΩ and 100 nF, completely different reaction depending on the sub. Interesting how sensitive some input stages can be.
If anyone has recommendations on a better way to implement the sub output, I am all ears.
Overall though, I am happy. The Pico 2 works, the recycled panel looks good, and with the DALI it is spot on.
Thanks Weeblabs.
Exactly like this. I xxl400 lives on my bedroom system and is crossed over using an sr6008 avr via LFE. Never had any issues. I also removed the pdm output from the diy board and placed it on a loose RCA and was getting the same issue.Do you have a series capacitor on PDM output? That sounds like one of your subwoofers is not AC coupled and is being fed the DC offset from the PDM output.
Ah, that is indeed the problem. Most but not all amplifiers are AC coupled. You need to place a 22uF capacitor in series with the tip pin of the RCA jack.Exactly like this. I xxl400 lives on my bedroom system and is crossed over using an sr6008 avr via LFE. Never had any issues. I also removed the pdm output from the diy board and placed it on a loose RCA and was getting the same issue.
Thanks for the documentation!I had success with the first one (yellow board) in this list (https://github.com/pschatzmann/ardu...02-i2s-iis-lossless-digital-audio-dac-decoder). Most of these devices seem to be compatible as well.
Nice. Can you test with some low frequency filters to confirm it doesn’t kill the noise floor?Loopback measurements look quite satisfactory. There remain a few minor issues to address, at which point I will be pushing a new release.
www.audiosciencereview.com
Can you really recover the clock from SPDIF on the Pico? This would require a digital PLL, wouldn't it?This is entirely possible. At the moment, I am working on 24-bit SPDIF output and squashing various minor bugs. Once that is in place, SPDIF input is next.
We may be able to mix SPDIF with USB but it is too early to be certain.![]()
At least I am curious how to connect "infinite" amout of Picos to a Mac using up-to 8ch over USB (at 24bits) - I was considering to output duplicates of one SPDIF out channel from one Pico to all Picos exactly as world-clock for an aggregate audio device - IF that is beneficial for Picos as aggregate output device?Can you really recover the clock from SPDIF on the Pico? This would require a digital PLL, wouldn't it?
Why would one want to mix SPDIF in and USB, i.e. what is the use case for that? How would you go about it? Lock to SPDIF and use the recovered clock as the master for the USB input?
