I am happy to announce the final release of
DSPi Firmware and
Console for macOS v1.1.6.
Just as a reminder, macOS users running v1.1.6 Beta 5 or newer will receive auto-update notifications both for Console and then for Firmware. There is no need to download anything manually. For the moment, this applies only to macOS users.
This release introduces some highly requested functionality and fixes a few longstanding bugs.
Here is the non-exhaustive list of changes:
- RP2350/2040: Audio latency is now adjustable from 0.6ms up to 8ms, with a default of 4ms. When USB input is selected, settings below 2ms have no effect.
- RP2350/2040: Each DSPi device can now be assigned a user-defined name that is stored on the device itself. It is visible both within the local Console and to all DSPi Link clients. This should drastically reduce confusion for users with multiple DSPi devices connected to the same Console.
- RP2350/2040: Each input source can now be assigned a user-defined name that is stored on the device itself. These names will also appear on connected displays via Control Surfaces.
- RP2350/2040: The current preset can now be saved via Control Surfaces.
- RP2350/2040: Bypassed PEQ band slots no longer remain in their bypassed state following a factory reset, loading or deleting an empty preset.
- RP2040: Channel meters no longer report levels as 6dB above their actual value. Clipping indicators now trigger at the correct level.
- DSPi Console for macOS: Spectrum analzyer rendering has been moved off the main thread, which eliminates stutters previously caused by various actions such as opening the Settings window.
- DSPi Console for macOS: The Networking settings page has been redesigned to make parameters more discoverable and comprehensible.
These system latency enhancements should enable more realtime music production use cases.
This week will be spent bringing Console for Windows and Linux up to feature parity, now that v1.1.6 is complete.
For those interested, both AC-3 and DTS decoding via SPDIF will be arriving with the early v1.1.7 betas. The functions are already available for testing in their respective branches, for users who might be experimentally inclined or wish to participate in testing.
The usual disclaimer: While great care has been taken to thoroughly test all functionality, some bugs may remain. Should you encounter a bug or unexpected behavior, please don't hesitate to make a report so that it can be squashed! You can do that either here, on
GitHub or via the
Discord server (many helpful people there).
Finally and as always, DSPi is a not-for-profit open source project funded entirely by donations and out of pocket. If you wish to support the project, you can do that via
Ko-fi or
Patreon.
