Introducing DSPi | A powerful, user friendly and open source DSP for less than a cup of coffee
That’s not a rat’s nest..
This is a rat’s nest!
One pcm1801 in, four pcm5102 out all wire wrapped and as always way to compact for my own sanity.
Hi, I couldn't find anything, maybe it was mentioned before... But could we have dithered 16bit I2S output for older DACs (i.e. the whole Philips range, but also CS4328, etc...)? blomquist spent €30. Thanks
I may have stayed up far too late working on it, bringing it up to full feature parity with Windows and macOS. :oops:
View attachment 562796 View attachment 562798View attachment 562797View attachment 562799
Some bugs may remain but in my limited testing (more tonight), everything appears to be working well. Having two existing codebases from which to port greatly accelerated the process.
Apart from some mild annoyances, it actually works really well, I'm glad I don't have to launch a Windows VM to use Console.
A bit more investigation into the volume level issue. I was playing music and after about half an hour the level on the right speaker suddenly became louder. Switching the source from SPDIF to USB and back restored back the correct level.
I've had a similar issue, not that only one channel goes louder, but one of my PCM5102 DACs ( I have four of them) goes louder in both channels, with swapping inputs as the solution. This does not apply to all my DACs though, only the one going to the subwoofer and one that's currently not in use.
What I think might be happening is that my power supply is not giving enough voltage. I measured the power going into my DACs and they got 3.7V despite expecting 5V. My low voltage is for several reasons, firstly I'm using a powered USB switcher so I can use the DSP without my computer running, but I also have a schottky diode and a big capacitor for my DACs to eliminate pops on power loss and this diode takes away some voltage.
Now I have changed some things around and gotten the voltage up to 4.2-4.5V ( it seem to fluctuate a bit) and the issues doesn't happen as often now, and hopefully it will be even less after I do a rebuild in a week or so.
So yeah, check your voltage is my suggestion. Your computer moght not give enough on its USB ports, a USB wall brick might not be enough, and a USB might be bad.
I'm glad it's working well for you. Could you describe some of those little annoyances?
The volume issue that you describe is typically caused by supply voltage or wiring issues. Do you have just one I2S DAC connected and is it on slot 1?
Nice work! My enclosure has half as many 5102s and is probably 4x as big. :facepalm::facepalm::facepalm::facepalm:
WWhat is this?? Stretch protection?
This is absolutely fantastic, a great answer to a question I had about 5 years ago, namely "Why can a $20 pair of headphones have 10-20 bands of PEQ under the hood, but I can't buy a simple box to do the same for less than $200?"
This might even be enough to get me to move away from EQAPO, I could also stop using Soundsource on my Mac work computer. I guess the only thing I'd miss would be crossfeed, so maybe I could be so bold as to put a feature request in the first comment... sorry :D
That said, probably still worth a go just for the discrete sub out...
11/10 contribution here!
Where would audio marketing be if they couldnt gouge us for dollars. Why do Sonos, Bose, and Apple have "Smart Amps" in their speaker offerings but no place else? Marketing is the answer. If we had the tech thats in "smart amps" implemented, integrated into Denon, Marantz, Sony, and the rest they would go out of business. You put smart amp tech into into mainstream electronics and you can keep your Amps for 10 to 15 years without needing to upgrade. You would no longer need $2500 Speaker wire. They do it all for you. On the other hand by making the tech proprietary you are kind of locked into their branding, Hello Apple.
I have two I2S PCM5102 DACs on outputs 1/2 and 3/4. I moved the supply to a power adapter and will report if the issue persists.
So far the app ignores the cursor theme and size. And when selecting outputs from the list on the main window, the slider values (for gain and delay) don't update between channels.
Values for gain and delay seem to be integers (you can't for example have a delay value less than 1 ms).
I only tested the appimage version since the AUR does not have the package yet.
View attachment 563023WWhat is this?? Stretch protection?
Ordinary mortals might think it’s an elastic band but it’s the most important item in my set up. The improvement in the detail, colour and topology of the sound is almost as breathtaking as the depth of the soundstage. You no longer just hear the music, you enter into the very minds not only of the performers but the original composer. I can let you have one for only $99,999.
Hi, I have a Focusrite Scarlett 2i2 sound card, and I want to connect its output to the PCM1808 ADC and then to the raspberry pico as suggested.
What circuit should I use between the XLR output of the 2i2 and the analog input of the PCM1808? Do I need any balanced-to-unbalanced/differential receiver or analog conditioning stage?
And also, what is the output signal level of the Focusrite 2i2's XLR line output, and how should I match/condition that signal to the PCM1808's required analog input level/range?
Is there a recommended circuit for connecting the Focusrite 2i2 output directly to the PCM1808?
Thank you!
Thank you!
You need another pcm1808. You'd use each one a mono input. You can set it up in dspi, effectively you setup the L/R of each adc to be L+/L- and R+/R- and simply invert one of the channels on each adc. This should give you a differential circuit that should behave fine with balanced I/O.
For an xlr plug wiring is basically ground to pin 1, L+ to pin 2, and L- to pin 3.
I dont like this method that much, better off getting a wondom a2d pcm 1822 which has stereo differential already setup. The jst plugs mean reduced soldering.
Latency is a tad on the high side for production work currently with dspi, not sure what your use case is but that might be annoying if you plan on tracking anything.
I have fixed these bugs and updated the current release in place. The cursor issue was indirectly caused by the AppImage route. AUR registrations are suspended at the moment, so it will take some time to get Console onto that repository.
Has the issue ever occurred on the DAC connected to output 1/2?
just curious—what sort of supply voltage issues would cause a volume increase? and is that behavior limited to certain types of inputs/outputs? could optical in/out ever be affected?
I've been running four 5102's just off the pico 2 3v line and haven't run into any issues. I should probably eventually give them 5v but I am lazy.
While the boards will continue to run at too low a supply voltage it's very likely that the sound they produce is degraded, particularly with louder music. You might want to test their output distortion (harmonic and intermod).
I remember it's output 2/3. I wanted to test this today but go figure, it hasn't done it.
Also all voltages are fine, I'm supplying the DACs from 5V and I also used a separate power adapter.
What made me believe it's not the DACs is the fact that if I soft reset the Pico via RUN, the issue goes away. And in this process the DACs stay on.
