Hi ,
I’m exploring the possibility of using DSPi with two balanced analog XLR inputs instead of USB audio from a PC, while retaining the existing DSP processing features such as PEQ, gain, delay, and crossover.
My idea is to use an external stereo ADC, such as the PCM1808, with a balanced analog front-end to convert the XLR inputs into digital audio and feed it to the Pico 2 via I2S.
I have a few questions:
- Does DSPi currently support I2S audio input, or is the audio processing pipeline designed exclusively around USB audio and other existing digital inputs?
- Would it be possible to connect an external ADC like the PCM1808 to the RP2350 and route its stereo audio into the existing DSP processing pipeline?
- If I wanted to implement this, what parts of the firmware would need to be modified? Would it mainly involve adding I2S input, DMA buffering, and routing the ADC's audio samples into the DSP pipeline?
- Are there any clocking or synchronization limitations I should consider when using an external ADC?
- Would this be feasible without significantly affecting the existing DSP performance or latency?
I noticed that SPDIF RX is on the roadmap, so I’m curious whether a similar approach could be used for an external analog ADC input.
Any guidance on the feasibility and the best way to approach this would be greatly appreciated. Thank you for developing and sharing DSPi!
