Introducing DSPi | A powerful, user friendly and open source DSP for less than a cup of coffee
I had issues with USB supply too. Phone chargers are notoriously noisy, so always use a power bank when ruling out noise.
Good to see on the SNR measurements. Totally agree on the numbers rabbit hole. They're good for checking something's in spec and ought to perform well, but once they're beyond audbible it's not clear that its useful.
Today I burned some tokens to port DSPi console for York DSP :D
Kinda works, except that some features of my DSP do not exist in DSPi and vice versa. Main point was to check how GUI looks and feels.
Since DSPi uses native OS API, it feels different and I like some of the UI features, quite clean design :)
Very impressive. I just downloaded yours and it's quite nice as well. (I see that 2x8 in there, yes please)
This project is really taking me back to the days of rockbox. Suddenly I feel the need to have DSPi run on everything.
It is my pleasure to announce the release of DSPi Firmware and Console for macOS v1.1.6 Beta 4. :)
Just as a reminder, Console for macOS will update the device firmware itself, so there's no need to download the latter separately.
This release focuses primarily on Console but naturally includes a handy set of additions to the firmware itself. The objective here is to prepare Console for the upcoming DSPi Link functionality.
Here is the non-exhaustive list of changes:
  • RP2350/2040: Tube Modeller offers accurate simulation of 16 popular vacuum tube models, complete with transformer output stage and detailed parameters for customization.
  • RP2350/2040: Limiters are now supported on all output channels and can be ganged within link groups.
  • RP2350/2040: USB communication has been optimized to significantly reduce the CPU load incurred on a host running Console
  • RP2350/2040: RAM usage has been optimized, freeing 17KB for future fucntionality.
  • RP2350/2040: Changing the volume of a USB host while listening to an non-USB input no longer produces incorrect volume readings on connected displays (Thanks to @bogdansrb).
  • Console for macOS: PEQ bands can now be edited directly on the graph display with a comprehensive array of keyboard shortcuts, new graphical elements and behaviors that will feel very familiar to users of FabFilter. There is also a detailed Readme that explains how everything works.
  • Console for macOS: Effect module windows have now been redesigned with a more elegant horizontal layout that should be much friendlier to smaller displays.
  • Console for macOS: Matrix Mixer now correctly displays the current name of each USB channel when in multichannel mode.
  • Console for macOS: CPU usage has been dramatically reduced through dozens of rendering optimizations, with typical usage now being just a tenth of what it had been in Beta 3.
  • Console for macOS: Stats for nerbs has been completely redesigned for increased legibility and now includes moving graphs for output buffer fill tracking.
I know that our Windows users are very eager to play with all of this new and I really appreciate your patience. Rest assured, it is on the way. I am currently working to introduce both the iOS and Android applications alongside DSPi Link, which is quite time consuming.
The usual disclaimer: While great care has been taken to thoroughly test all functionality, this is beta software and some bugs may remain. Should you encounter a bug or unexpected behavior, please don't hesitate to make a report so that it can be squashed! You can do that either here, on GitHub or via the Discord server (many helpful people there).
Finally and as always, DSPi is a not-for-profit open source project funded entirely by donations and out of pocket. If you wish to support the project, you can do that via Ko-fi or Patreon.
Unless, I suppose, you enjoy a degraded signal... but hey, to each their own.
Still, this site promotes the most neutral possible reproduction of the source signal. So, while I can see the point of simulating bass for anemic 2-way speakers, the appeal of these tube gadgets completely escapes me. That said, it’s a nice extra feature for those who might actually use it.
In any case, I’m not really sure where this project is heading anymore. I understand the desire to do "as much as possible", even if it means mimicking existing products or outright copying them. VST support would have been a viable solution in that regard, though perhaps incompatible with the limited memory on the boards. Even so, that’s not a sufficient excuse; and - without wanting to be a buzzkill (because I love the project) - I do find myself questioning the legality or inconsistency of some of these proposals.
But, that doesn't stop me from thinking that your involvement and the work you've produced are remarkable. Even so, it seems fair to question certain choices.
A number of users requested tube modelling and while admittedly its appeal also escapes me, the function cost almost nothing to implement.
The objective is not really to do as much as possible but to do most of the things that listeners are likely to want.
At the moment, this is the project roadmap:
- DSPi Link and mobile applications (Network control)
- Analog PWM output overhaul (Any output slot(s) assignable)
- Selectable system clocks and voltages (Increased performance)
- Automated room correction
- SPDIF RX and Soft VCXO overhaul (Cleaner clocks)
Would this by chance mean one could drop latency? It's not really a common use case with DSPi and the current latency is fine for pretty much everyone, but it would be neat to play some piano through my DSP'd speakers.
Fair enough, I get it. But implementing tube simulation before the "compression" stage for tweeters (even if I personally wouldn't have any use for it), is a choice that is questionable, to say the least.
That said, the upcoming features are certainly interesting.
- Automated room correction? For free? Who among us hasn't dreamed of that? (Though, of course, we'll have to see how well it actually performs...)
- SPDIF RX and Soft VCXO overhaul (cleaner clocks)? That’s also a step in the right direction.
As I said, the intentions are generally praiseworthy; it’s just that certain choices raise questions (whether valid or not...).
Thank you, this works as expected now.
Is there more info on how DSPi Link works?
Let them cook!
If there are features available that make no sense TO YOU, just like forum posts you disagree with, they are best just ignored.
I was HUGELY gratified to see the Subharmonic Synthesizer feature materialize, solves all kinds of AD/DA routing complications for me.
Loudness Compensation is critical for me
Can't wait to check out Headphone Crossfeed!
etc etc
So long as the UX and quality of the key functionalities do not suffer, why not? DSP can benefit our systems in so many ways!!
This is a spare time project and I do imagine Troy doing a balance of what "needs" to be done and what he thinks is fun. I did see that someone requested tube distortion with Troy instantly building it, ie it looked like he though it was a fun thing to do and therefor he did it. I often do the same, I have a big project that I'm doing, but I get caught up in some small thing that maybe doesn't matter that much but is just fun to do.
If Troy can also make the latency go down I can imagine someone in the future for example doing a guitarr pedal with DSPi and the tube simulator drive at max. Maybe Troy could also implement reverb, a phaser and flanger as well for other fun effect boxes? ;)
Let them cook!
etc etc
Valid points. As a friendly counterargument, I would put forward that discussion drives the development direction, and time and processing resources aren't free, so some respectful feedback on features isn't entirely unreasonable in the thread :)
I once listened to Wish You Were Here on a highly regarded tube amp and had one of those genuine “hairs standing up” moments. Would I buy one? No, because I didn't like what it did with modern electronic music, and it absolutely ruined Radiohead for me.
And if you follow the Discord, you'll know Troy had this feature built in within a couple of hours. So if users want it and it takes relatively little development time, I'm not sure why its inclusion is particularly controversial.
I’m not sure it’s reasonable to complain if someone’s project, that they voluntarily and generously share with the community, does not go in some particular direction. DSPi is astonishing. It’s 100% open source. It does what commercial products costing twenty or fifty times more struggle to achieve. It is amazingly flexible yet stable and robust. Nor does it require anything more than very modest beginner level computing or DIY skills. Total respect to Troy!
I don't think it is questionable at all. Many, if not most, modern recordings already are compressed, and sometimes suffer because of it. I would not add additional compression, and would not add compression to an uncompressed recording. I suspect most people concerned enough about high quality audio to use DSPi probably feel the same. However, it might be fun to play with the tube simulation for certain recordings.
The intentions are way, way more than "generally praiseworthy". The gentleman obviously put a lot of work into this project and is sharing it with everyone for free. That is highly praiseworthy. And, DSPi is his project, so his choices. Sure, he may appreciate hearing feedback, but stating that "certain choices raise questions" comes off as being a little presumptuous. Perhaps that was not your intent, but that is the way it comes across.
The developer controls how they spend their time, and unused features do not consume user resources.
And this project's productivity throughput has been just mind boggling...
Troy is doing an amazing job for sure and I've been happy to contribute to his fund. And yes the commenter could have perhaps worded his feedback better.
