Tell
- Joined
- Mar 30, 2024
- Messages
- 1,069
- Likes
- 1,513
Both is already possibleI haven't found a way to switch sources from a control surface. Maybe it's planned. But you can change volume.
Output toggles would be a nice feature.
Wow that's cool. I was looking for a single button to cycle between all sources. But 2 extra buttons don't hurt.
You can configure a single button to loop through all input sources. Yes, 1602 displays are supported.Wow that's cool. I was looking for a single button to cycle between all sources. But 2 extra buttons don't hurt.
If we're at it, I saw something about displays. Are 16x2 LCDs supported? I have a single Windows machine at work so I can't check Console right now.
Sorry, I don't understand, i only have PDM plus all output SPDIF. PDM would act as 0-1 output if I choose it?
I got it working but when it reaches I2S it doesn't cycle back to USB (which is what "wrap around at the ends" should do). Also I don't have an option for displays.You can configure a single button to loop through all input sources. Yes, 1602 displays are supported.
It sounds as though you may be running an older Console and/or Firmware version; possibly one prior to Displays and the effect module multichannel rework.I got it working but when it reaches I2S it doesn't cycle back to USB (which is what "wrap around at the ends" should do). Also I don't have an option for displays.
I'm glad it's working! The only display that I actually have on hand for testing is an old 1602, so I'll be using some project funds to order a batch of components that includes all of the currently supported displays. What you see on that SSH1106 is by no means the final form.I received the OLED SH1106 today. It even works. But is it possible to make the font size extra large? It's impossible to see anything from two meters away, and half the screen is blank.
This can be accomplished in the current release using Macros but the next beta will include explicit support for user defined nouns.Hello,
I (maybe) would like to use it with only one rotary encoder with following functionnality:
- turn to change volume
- push to change source
- long push to turn on/off the system (230V voltage input), by controlling a solid state relay.
For the last, I would need to toggle an output on the pico, but I did not find a way to do it? Is it possible/planned to create random outputs?
This was solved, I was building from the main repo. But this is still not working.It sounds as though you may be running an older Console and/or Firmware version; possibly one prior to Displays and the effect module multichannel rework.
Loudness compensation and Psychoacoustic Bass don't work on the SPDIF input. They can be enabled but have no effect.
Could you possibly share some additional details of your control setup? I know that @Kingsnake routinely uses loudness compensation on SPDIF sources without issue. It is driven by User Volume rather than the level of the source, as SPDIF embeds no volume control.This was solved, I was building from the main repo. But this is still not working.
I have a rotary encoder that controls User Volume and Source Select (via the pushbutton). Master Volume is set at 0dB. When I cycle through the sources with Loudness Compensation enabled, for example, I can hear it in action on the USB source, but not on the SPDIF.Could you possibly share some additional details of your control setup? I know that @Kingsnake routinely uses loudness compensation on SPDIF sources without issue. It is driven by User Volume rather than the level of the source, as SPDIF embeds no volume control.
If you are using a TV as your source. You may have a option to set the Digital audio output format: set it to PCM, rather than Bitstream / Dolby Digital / Pass-through.I have a rotary encoder that controls User Volume and Source Select (via the pushbutton). Master Volume is set at 0dB. When I cycle through the sources with Loudness Compensation enabled, for example, I can hear it in action on the USB source, but not on the SPDIF.
Other than that, it's SPDIF in - I2S out. Loudness is enabled on all channels.
The SPDIF signal is coming from a PC motherboard.If you are using a TV as your source. You may have a option to set the Digital audio output format: set it to PCM, rather than Bitstream / Dolby Digital / Pass-through.
