Thanks a lot for the details; I have a better understanding of the ins and outs now.I think it's a good idea for @Kingsnake to make sure his boards work first if he ordered them - just to ensure the files I posted at Github are what I think they are. The gerbers came from JLCPCB (the last build I did) but the pick and place and bom were generated by the design app when I posted the Github files.
As for the additional testing and stuff... I did a bunch of tests but only saved the usual characteristic tests. I stopped the test at 0.9VRMS because
a) the usual voltage test level is spec'ed at -1 dBFs (I used -1 dBV)
b) I was worried about DSPi and Windows clipping the signal since essentially all volumes have to be set full on to hit 2VRMS
c) the QA403 test box has a hard input limit of 1VRMS at the lowest noise - to measure 2V raises the measurement noise 6dB and lowers the measured SN ratio and the board is so good that it's hitting the QA403 noise floor. I can't accurately test at 2VRMS.
I think the frequency response is down about 1-1.5 dB at 20KHz per TI's spec. I went back and forth about using a different output filter and did end up improving the quality but left the bandwidth at the TI spec. Also, changing their internal digital filter takes I2C initialization which I wasn't going to do. I may be wrong about this but consider it inaudible either way. You can desolder the output cap if you want no external output filter.
Mark
In any case, I’ll wait to see what others do with it. There’s no rush on my end.
Like others accustomed to the "nanodigi," I was planning to use an external DAC per channel (Toslink to RCA or XLR, such as the SMSL PS200 PRO, SU1, or SU2, etc.). But obviously, if there’s an alternative that offers comparable performance, is easy to integrate, and costs less, that’s always preferable...
