Introducing DSPi | A powerful, user friendly and open source DSP for less than a cup of coffee
Thanks Mark,
For me five PCB boards for £75 delivered, working out at just £15.14 per board all-in.
(JLCPCB and all components in stock for a change)
Excellent value for money, with a very well thought out design and a great choice of components.
I only wish I needed more than 1.
Thanks Mark,
Maybe we could do an European group buy...?
I would also be interested in purchasing at least four boards. :)
+1, for four boards.
Following a little bit of investigation and calculation, I have found that if we place a panelized order for 100pcs, that would make economical sense. The initial order would cost about €322.
At that quantity, each piece would cost about €3.90 with initial shipping and VAT. Cost to the individudal buyer for 4pcs would be a total of about €20 with EU distribution. Or €38 for 8pcs.
€20 for eight channels is excellent!
EDIT: There are apparently some cheaper shipping options available, so these amounts could actually be even lower. €288 for the initial order, potentially.
if yyou want to use several in parallel for multichannel system, it might be a good idea to add a footprint for a clock buffer (i.e. LMK1C1104DQFR) and use one to distribute clocks to the others.
I could use four, in the UK.:)
Note the boards don't support master operation (there is no mclk exposed). The doc recommends using their onboard synch and not running master/slave so I didn't bother adding it to the board design. I didn't look into it too carefully but I'm pretty sure it's not available.
I take it that everyone who makes an 8-channel DAC already has an 8-channel amplifier? :) Because if you're making a budget solution, there are plenty of amplifier chips with an I2S input. In that case, the return on investment is higher. That's exactly what I'm trying to made.
Still sharing Bitclock, isn't it? Well, if the frequency is not too high it might not be a problem, or maybe it isn't a problem anyways, I meant just as an "in case". LRCLK is normally nothing to worry about.
Some channels require lots more power than others.
Some use active speakers.
Some use cases the output feeds another line level device.
Choices are good.
A modular board that allows for not just analog out but in, and/or ADAT vs AES3 vs S/PDIF I/O would be ideal.
Wondom JAB6 is an interesting approach that way, but no preamp bypass of the amp.
The board looks good, but it seems to me there are a few points that need clarification...
Why was the distortion vs. voltage graph capped at 0.9V instead of the maximum 2V?
Can we see the frequency response? What type of output filter is used?
There is no fixed standard, but 2Vrms (unbalanced) and a minimum of 4Vrms (balanced) are very often the input levels required to drive amplifiers to full power. If it's limited to 2V balanced here, that could be problematic...
Edit : While reading the TAD5242 datasheet, I realize that it's a limitation imposed by the chip...
That said, once all this is clarified (and the more info, the better), it could certainly be an interesting option... Personally, I don't have enough data to commit to ordering 4 to 16 units... even though the price is obviously tempting!
Can we get more information? More measurements?
I think it's a good idea for @Kingsnake to make sure his boards work first if he ordered them - just to ensure the files I posted at Github are what I think they are. The gerbers came from JLCPCB (the last build I did) but the pick and place and bom were generated by the design app when I posted the Github files.
As for the additional testing and stuff... I did a bunch of tests but only saved the usual characteristic tests. I stopped the test at 0.9VRMS because
a) the usual voltage test level is spec'ed at -1 dBFs (I used -1 dBV)
b) I was worried about DSPi and Windows clipping the signal since essentially all volumes have to be set full on to hit 2VRMS
c) the QA403 test box has a hard input limit of 1VRMS at the lowest noise - to measure 2V raises the measurement noise 6dB and lowers the measured SN ratio and the board is so good that it's hitting the QA403 noise floor. I can't accurately test at 2VRMS.
I think the frequency response is down about 1-1.5 dB at 20KHz per TI's spec. I went back and forth about using a different output filter and did end up improving the quality but left the bandwidth at the TI spec. Also, changing their internal digital filter takes I2C initialization which I wasn't going to do. I may be wrong about this but consider it inaudible either way. You can desolder the output cap if you want no external output filter.
Mark
I haven't ordered any myself yet, but if Troy wants to get a batch made for testing, I'd be happy to donate £20 towards the cost through his Ko-fi as a contribution towards the work he's put into the project.
The five assembled boards are coming out at roughly £75.
Would anyone else be willing to chip in a little towards a sample batch as well?
