1k input impedance is very low. Most of my gear is going have issue with that. The l30 at 2.4k is already a concern but may just be OK.
LOL, it's like they left off a zero or two...
Noise (A-wt): 0.95 uV, potentiometer at nil
Maybe take a vote? I'm going to buy it one way or another, even if it's different from the current version.If that's what you guys want I can change that in a snap. The gain settings.
didn't I just see you post about racial stereotypes in another thread?So how did the audio goblin overhype this product? lol
Well, at least it reflects the output buffer's noise, which still means something. Also, with sensitive IEMs you only need to increase the volume just a little bit, so I am expecting the noise to be very low till 9-10 o'clock as well.At "nil" a typical potentiometer shorts the wiper to the end of the track. It's essentially a shorted input spec.
Perhaps if they gave us a worst case noise spec through the pot rotation instead of a best case it'd mean something.
Off-toppic, I know and sorry for this!If that's what you guys want I can change that in a snap. The gain settings.
L30 is stayed as that. Original design was to keep clipping out of the way and the gain settings are more comfortable to toggle between without too much jump. A30pro will need larger gain.Off-toppic, I know and sorry for this!
Given that most DACs are outputting between 2...2.3 V RMS, I consider a real highlight for L30 having a higher gain (unless it's a marketing decision). This way it will start clipping @ 32 Ohms close to max. potentiometer level when feed with 2.1-2.2 V and it will drive even more hard-to-drive cans.
I was using my uber-sensitive IEMs (about 122 dB/V SPL @ 20 Ohms) with unity gain headamps with success and I never felt that I needed a lower gain than unity. I do understand the importance of the -9 dB gain setting (hearing safety is a top priority here), but I still find it too low. Maybe -6 dB would make much sense...just my 2 cents.
As for the highest gain I would anytime swap 9 dB gain with 12 dB gain.
Looking further for some measurements on this THX-AAA-One headamp, especially the 50 mV SINAD versus the L30 with unity gain.
I think the gain is fine, -9dB I usually max out, untill I need more and go to unity gain. High gain I use very rarely, and for those that need more power than l30, upcoming A30 Pro seems perfect candidateL30 is stayed as that. Original design was to keep clipping out of the way and the gain settings are more comfortable to toggle between without too much jump. A30pro will need larger gain.
Looks pretty bland for a $200 product.
