Try playing around with the 'Filter' settings in the enclosure tool.From what I can see by a quick look both VCAD and WinISD have decent size databases. However, neither is suitable to my purpose, which is to quickly "scroll through" drivers (preferably with min-max diameter and power limits), eliminate the unsuitable ones and feed the suitable ones to a list (favourites). This will allow the designer to then use the secondary criteria to reduce the list even further (like price, availability, diameter, power handling, etc.) This will make the life of DIY speaker builder much more easier than having to select each driver one by one and relying on memory. In short I'm looking for a tool that helps me to select drivers suitable for my enclosure.
Meanwhile, Speaker Box Lite seems to have range selection for various criteria. I will spend more time on this and report. If it interests me enough I will create a new thread in order not to pollute this thread further.
Thank you for helping this 71 year old ex-speaker manufacturer who has not been involved with speaker design since mid 90s.
I admit, its not novice friendly. But its form follows function, and its very good once you got it figured out.
