ctrl
but decided to share the latest form @ctrl.
There seems to be something wrong with the settings or parameter - attach the file too (but probably it's a problem with different option settings in VCAD).
It should look like this. It's a LR second order crossover. It should sound kind of warm, but you have to adjust the sound pressure level of the tweeter, because I never heard the speaker.
The crossover was adapted for the miniDSP 48k. Who uses another DSP must make adjustments.
The example crossover is only to show the possible potential of the speaker - which is extremely promising for the simple design. When comparing the crossover simulation of version v9d with other ASR measurements of loudspeakers, the potential becomes immediately obvious.
As Rick said, if you want to build the speaker, you have to have measurement equipment and be able to use it - everything else is probably doomed
