ctrl
If you set a very slightly decreasing frequency response (about 1dB) in the low frequency range, via crossover, then [email protected]@1m sensitivity is realistic. This is then the sensitivity of the speaker at 2.83V, whether passive or active.With the crossover developed by @ctrl, am getting a bit over 90 dB at 2.83V/1m. Am expecting it will stay around that number when Amir measures.
The shelfing filter in the crossover simply raises the low frequency range massively by 6-8dB, but the amplifier power for this must also be generated somewhere. An active crossover does not "conjure up" a 7-8dB sensitivity increase
If the Directiva is used down to 80Hz with a subwoofer, then up to 106dB is realistic for a short time, maybe a bit more. If the signal covers the full frequency range (20Hz-20kHz), then at 106dB the woofer and the PR reach the limit for linear excursion.I've been looking for a small Speaker that can do ~115 dBSPL at 1 meter (above 100Hz) with sensible sensitivity to boot.
But this requires 400W amplifier power (with 600W 108dB would be possible for a short time).
The SeasDXT tweeter would probably handle this as well, as has already been shown here.
But to reach 115dB regularly, with acceptable amplifier power, the Directiva is not suitable.
For this you should use PA drivers and consider a compression driver for the high frequency. A sensitivity of [email protected]@1m is then possible.
But if you want to cross over at 80Hz to the subwoofer, a 6'' driver will or/and could probably not play low enough. You may need to increase the crossover to the subwoofer to 100Hz.
