When connecting the isolator when RPi5 is running - what does 'dmesg -w' output?
It outputs a lot:
<root@DietPi63:~# dmesg -w
[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x414fd0b1]
[ 0.000000] Linux version 6.6.74+rpt-rpi-2712 (
[email protected]) (gcc-12 (Debian 12.2.0-14) 12.2.0, GNU ld (GNU Binutils for Debian) 2.40) #1 SMP PREEMPT Debian 1:6.6.74-1+rpt1 (2025-01-27)
[ 0.000000] KASLR enabled
[ 0.000000] random: crng init done
[ 0.000000] Machine model: Raspberry Pi 5 Model B Rev 1.0
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x0000000002000000, size 64 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] OF: reserved mem: 0x0000000002000000..0x0000000005ffffff (65536 KiB) map reusable linux,cma
[ 0.000000] OF: reserved mem: 0x0000000000000000..0x000000000007ffff (512 KiB) nomap non-reusable atf@0
[ 0.000000] OF: reserved mem: 0x000000003fd16cc0..0x000000003fd16cf7 (0 KiB) nomap non-reusable nvram@0
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0xffd892c0-0xffd8bfff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal empty
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000000007ffff]
[ 0.000000] node 0: [mem 0x0000000000080000-0x000000003fbfffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000000ffffffff]
[ 0.000000] On node 0, zone DMA: 256 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 14 pages/cpu s184232 r8192 d36952 u229376
[ 0.000000] pcpu-alloc: s184232 r8192 d36952 u229376 alloc=14*16384
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU features: detected: Hardware dirty bit management
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] CPU features: detected: SSBS not fully self-synchronizing
[ 0.000000] alternatives: applying boot alternatives
[ 0.000000] Kernel command line: reboot=w coherent_pool=1M 8250.nr_uarts=1 pci=pcie_bus_safe cgroup_disable=memory numa_policy=interleave smsc95xx.macaddr=2C:CF:67:36:83:B3 vc_mem.mem_base=0x3fc00000 vc_mem.mem_size=0x40000000 root=PARTUUID=617f9ab6-02 rootfstype=ext4 rootwait net.ifnames=0 logo.nologo console=tty1 cgroup_enable=memory
[ 0.000000] cgroup: Disabling memory control group subsystem
[ 0.000000] mempolicy: NUMA default policy overridden to 'interleave:0'
[ 0.000000] cgroup: Enabling memory control group subsystem
[ 0.000000] Dentry cache hash table entries: 524288 (order: 8, 4194304 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 7, 2097152 bytes, linear)
[ 0.000000] Fallback order for Node 0: 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 260864
[ 0.000000] Policy zone: DMA
[ 0.000000] mem auto-init: stack:all(zero), heap alloc
ff, heap free
ff
[ 0.000000] Memory: 4071440K/4190208K available (13504K kernel code, 2220K rwdata, 4320K rodata, 5120K init, 1216K bss, 53232K reserved, 65536K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 43544 entries in 43 pages
[ 0.000000] ftrace: allocated 43 pages with 4 groups
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000000] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000111] Console: colour dummy device 80x25
[ 0.000114] printk: console [tty1] enabled
[ 0.000244] Calibrating delay loop (skipped), value calculated using timer frequency.. 108.00 BogoMIPS (lpj=216000)
[ 0.000251] pid_max: default: 32768 minimum: 301
[ 0.000271] LSM: initializing lsm=capability,integrity
[ 0.000316] Mount-cache hash table entries: 8192 (order: 2, 65536 bytes, linear)
[ 0.000329] Mountpoint-cache hash table entries: 8192 (order: 2, 65536 bytes, linear)
[ 0.000854] RCU Tasks: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000881] RCU Tasks Rude: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000902] RCU Tasks Trace: Setting shift to 2 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=4.
[ 0.000955] rcu: Hierarchical SRCU implementation.
[ 0.000958] rcu: Max phase no-delay instances is 1000.
[ 0.001384] EFI services will not be available.
[ 0.001447] smp: Bringing up secondary CPUs ...
[ 0.001586] Detected PIPT I-cache on CPU1
[ 0.001620] CPU1: Booted secondary processor 0x0000000100 [0x414fd0b1]
[ 0.001766] Detected PIPT I-cache on CPU2
[ 0.001788] CPU2: Booted secondary processor 0x0000000200 [0x414fd0b1]
[ 0.001918] Detected PIPT I-cache on CPU3
[ 0.001937] CPU3: Booted secondary processor 0x0000000300 [0x414fd0b1]
[ 0.001957] smp: Brought up 1 node, 4 CPUs
[ 0.001971] SMP: Total of 4 processors activated.
[ 0.001974] CPU features: detected: 32-bit EL0 Support
[ 0.001977] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.001981] CPU features: detected: Common not Private translations
[ 0.001983] CPU features: detected: CRC32 instructions
[ 0.001986] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.001988] CPU features: detected: LSE atomic instructions
[ 0.001991] CPU features: detected: Privileged Access Never
[ 0.001993] CPU features: detected: RAS Extension Support
[ 0.001996] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.002022] CPU: All CPU(s) started at EL2
[ 0.002024] alternatives: applying system-wide alternatives
[ 0.003538] devtmpfs: initialized
[ 0.005704] Enabled cp15_barrier support
[ 0.005714] Enabled setend support
[ 0.005766] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.005773] futex hash table entries: 1024 (order: 2, 65536 bytes, linear)
[ 0.006007] pinctrl core: initialized pinctrl subsystem
[ 0.006111] DMI not present or invalid.
[ 0.006237] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.006647] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.006682] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.006716] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.006732] audit: initializing netlink subsys (disabled)
[ 0.006773] audit: type=2000 audit(0.004:1): state=initialized audit_enabled=0 res=1
[ 0.006864] thermal_sys: Registered thermal governor 'step_wise'
[ 0.006873] cpuidle: using governor menu
[ 0.006922] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.006943] ASID allocator initialised with 32768 entries
[ 0.007158] Serial: AMBA PL011 UART driver
[ 0.007794] bcm2835-mbox 107c013880.mailbox: mailbox enabled
[ 0.008061] 107d001000.serial: ttyAMA10 at MMIO 0x107d001000 (irq = 15, base_baud = 0) is a PL011 rev3
[ 0.015993] raspberrypi-firmware soc:firmware: Attached to firmware from 2024-09-23T13:02:56, variant start_cd
[ 0.019995] raspberrypi-firmware soc:firmware: Firmware hash is 2682625900000000000000000000000000000000
[ 0.024797] /axi/pcie@120000/rp1: Fixed dependency cycle(s) with /axi/pcie@120000/rp1
[ 0.024858] /axi/interrupt-controller@7fff9000: Fixed dependency cycle(s) with /axi/interrupt-controller@7fff9000
[ 0.025027] /axi/pcie@120000/rp1: Fixed dependency cycle(s) with /axi/pcie@120000/rp1
[ 0.025599] Modules: 2G module region forced by RANDOMIZE_MODULE_REGION_FULL
[ 0.025603] Modules: 0 pages in range for non-PLT usage
[ 0.025604] Modules: 129400 pages in range for PLT usage
[ 0.028509] bcm2835-dma 1000010000.dma: DMA legacy API manager, dmachans=0x1
[ 0.028767] iommu: Default domain type: Translated
[ 0.028770] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.028831] SCSI subsystem initialized
[ 0.028859] usbcore: registered new interface driver usbfs
[ 0.028866] usbcore: registered new interface driver hub
[ 0.028879] usbcore: registered new device driver usb
[ 0.028939] pps_core: LinuxPPS API ver. 1 registered
[ 0.028942] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <
[email protected]>
[ 0.028946] PTP clock support registered
[ 0.029161] vgaarb: loaded
[ 0.029236] clocksource: Switched to clocksource arch_sys_counter
[ 0.029329] VFS: Disk quotas dquot_6.6.0
[ 0.029339] VFS: Dquot-cache hash table entries: 2048 (order 0, 16384 bytes)
[ 0.029363] FS-Cache: Loaded
[ 0.029673] CacheFiles: Loaded
[ 0.030569] NET: Registered PF_INET protocol family
[ 0.030647] IP idents hash table entries: 65536 (order: 5, 524288 bytes, linear)
[ 0.031452] tcp_listen_portaddr_hash hash table entries: 2048 (order: 1, 32768 bytes, linear)
[ 0.031476] Table-perturb hash table entries: 65536 (order: 4, 262144 bytes, linear)
[ 0.031480] TCP established hash table entries: 32768 (order: 4, 262144 bytes, linear)
[ 0.031568] TCP bind hash table entries: 32768 (order: 6, 1048576 bytes, linear)
[ 0.032409] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.032524] MPTCP token hash table entries: 4096 (order: 2, 98304 bytes, linear)
[ 0.032570] UDP hash table entries: 2048 (order: 2, 65536 bytes, linear)
[ 0.032608] UDP-Lite hash table entries: 2048 (order: 2, 65536 bytes, linear)
[ 0.032684] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.032806] RPC: Registered named UNIX socket transport module.
[ 0.032810] RPC: Registered udp transport module.
[ 0.032812] RPC: Registered tcp transport module.
[ 0.032814] RPC: Registered tcp-with-tls transport module.
[ 0.032816] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.032821] PCI: CLS 0 bytes, default 64
[ 0.037283] kvm [1]: IPA Size Limit: 40 bits
[ 0.037298] kvm [1]: GICV region size/alignment is unsafe, using trapping (reduced performance)
[ 0.037317] kvm [1]: vgic interrupt IRQ9
[ 0.037328] kvm [1]: VHE mode initialized successfully
[ 0.208211] Initialise system trusted keyrings
[ 0.208264] workingset: timestamp_bits=42 max_order=18 bucket_order=0
[ 0.208279] zbud: loaded
[ 0.208423] NFS: Registering the id_resolver key type
[ 0.208431] Key type id_resolver registered
[ 0.208433] Key type id_legacy registered
[ 0.208437] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.208440] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.208471] F2FS not supported on PAGE_SIZE(16384) != 4096
[ 0.208511] Key type asymmetric registered
[ 0.208514] Asymmetric key parser 'x509' registered
[ 0.208525] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.208562] io scheduler mq-deadline registered
[ 0.208565] io scheduler kyber registered
[ 0.208573] io scheduler bfq registered
[ 0.208739] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7c502000, parent irq: 26)
[ 0.208784] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d503000, parent irq: 27)
[ 0.208814] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508380, parent irq: 28)
[ 0.208849] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d508400, parent irq: 29)
[ 0.208884] irq_brcmstb_l2: registered L2 intc (/soc/interrupt-controller@7d510600, parent irq: 30)
[ 0.208915] irq_brcmstb_l2: registered L2 intc (/soc/intc@7d517b00, parent irq: 31)
[ 0.238100] Serial: 8250/16550 driver, 1 ports, IRQ sharing enabled
[ 0.238384] 107d50c000.serial: ttyS0 at MMIO 0x107d50c000 (irq = 33, base_baud = 6000000) is a Broadcom BCM7271 UART
[ 0.238420] serial serial0: tty port ttyS0 registered
[ 0.238626] iproc-rng200 107d208000.rng: hwrng registered
[ 0.238664] vc-mem: phys_addr:0x00000000 mem_base=0x3fc00000 mem_size:0x40000000(1024 MiB)
[ 0.238821] bcm2712-iommu-cache 1000005b00.iommuc: bcm2712_iommu_cache_probe
[ 0.240143] brd: module loaded
[ 0.241214] loop: module loaded
[ 0.241329] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 0.241429] Loading iSCSI transport class v2.0-870.
[ 0.242059] usbcore: registered new device driver r8152-cfgselector
[ 0.242067] usbcore: registered new interface driver r8152
[ 0.242073] usbcore: registered new interface driver lan78xx
[ 0.242078] usbcore: registered new interface driver smsc95xx
[ 0.242120] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 0.242135] dwc_otg: FIQ enabled
[ 0.242137] dwc_otg: NAK holdoff enabled
[ 0.242138] dwc_otg: FIQ split-transaction FSM enabled
[ 0.242139] Module dwc_common_port init
[ 0.242231] usbcore: registered new interface driver uas
[ 0.242238] usbcore: registered new interface driver usb-storage
[ 0.242306] mousedev: PS/2 mouse device common for all mice
[ 0.249624] rpi-rtc soc:rpi_rtc: registered as rtc0
[ 0.250978] rpi-rtc soc:rpi_rtc: setting system clock to 1970-01-01T00:00:08 UTC (8)
[ 0.251213] bcm2835-wdt bcm2835-wdt: Poweroff handler already present!
[ 0.251217] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 0.253370] sdhci: Secure Digital Host Controller Interface driver
[ 0.253374] sdhci: Copyright(c) Pierre Ossman
[ 0.253401] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.253542] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.253577] SMCCC: SOC_ID: ARCH_SOC_ID not implemented, skipping ....
[ 0.253587] hid: raw HID events driver (C) Jiri Kosina
[ 0.253607] usbcore: registered new interface driver usbhid
[ 0.253610] usbhid: USB HID core driver
[ 0.253825] hw perfevents: enabled with armv8_cortex_a76 PMU driver, 7 counters available
[ 0.254078] NET: Registered PF_PACKET protocol family
[ 0.254101] Key type dns_resolver registered
[ 0.257862] registered taskstats version 1
[ 0.257923] Loading compiled-in X.509 certificates
[ 0.259680] Key type .fscrypt registered
[ 0.259685] Key type fscrypt-provisioning registered
[ 0.260221] brcm-pcie 1000120000.pcie: host bridge /axi/pcie@120000 ranges:
[ 0.260228] brcm-pcie 1000120000.pcie: No bus range found for /axi/pcie@120000, using [bus 00-ff]
[ 0.260238] brcm-pcie 1000120000.pcie: MEM 0x1f00000000..0x1ffffffffb -> 0x0000000000
[ 0.260243] brcm-pcie 1000120000.pcie: MEM 0x1c00000000..0x1effffffff -> 0x0400000000
[ 0.260250] brcm-pcie 1000120000.pcie: IB MEM 0x1f00000000..0x1f003fffff -> 0x0000000000
[ 0.260255] brcm-pcie 1000120000.pcie: IB MEM 0x0000000000..0x0fffffffff -> 0x1000000000
[ 0.261529] brcm-pcie 1000120000.pcie: Forcing gen 2
[ 0.261693] brcm-pcie 1000120000.pcie: PCI host bridge to bus 0000:00
[ 0.261697] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.261701] pci_bus 0000:00: root bus resource [mem 0x1f00000000-0x1ffffffffb] (bus address [0x00000000-0xfffffffb])
[ 0.261705] pci_bus 0000:00: root bus resource [mem 0x1c00000000-0x1effffffff pref] (bus address [0x400000000-0x6ffffffff])
[ 0.261719] pci 0000:00:00.0: [14e4:2712] type 01 class 0x060400
[ 0.261741] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.262309] pci 0000:00:00.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 0.369243] brcm-pcie 1000120000.pcie: link up, 5.0 GT/s PCIe x4 (!SSC)
[ 0.369267] pci 0000:01:00.0: [1de4:0001] type 00 class 0x020000
[ 0.369281] pci 0000:01:00.0: reg 0x10: [mem 0xffffc000-0xffffffff]
[ 0.369289] pci 0000:01:00.0: reg 0x14: [mem 0xffc00000-0xffffffff]
[ 0.369296] pci 0000:01:00.0: reg 0x18: [mem 0xffff0000-0xffffffff]
[ 0.369361] pci 0000:01:00.0: supports D1
[ 0.369364] pci 0000:01:00.0: PME# supported from D0 D1 D3hot D3cold
[ 0.381243] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 0.381254] pci 0000:00:00.0: BAR 8: assigned [mem 0x1f00000000-0x1f005fffff]
[ 0.381259] pci 0000:01:00.0: BAR 1: assigned [mem 0x1f00000000-0x1f003fffff]
[ 0.381264] pci 0000:01:00.0: BAR 2: assigned [mem 0x1f00400000-0x1f0040ffff]
[ 0.381269] pci 0000:01:00.0: BAR 0: assigned [mem 0x1f00410000-0x1f00413fff]
[ 0.381274] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.381277] pci 0000:00:00.0: bridge window [mem 0x1f00000000-0x1f005fffff]
[ 0.381282] pci 0000:00:00.0: Max Payload Size set to 256/ 512 (was 128), Max Read Rq 512
[ 0.381291] pci 0000:01:00.0: Max Payload Size set to 256/ 256 (was 128), Max Read Rq 512
[ 0.381352] pcieport 0000:00:00.0: enabling device (0000 -> 0002)
[ 0.381383] pcieport 0000:00:00.0: PME: Signaling with IRQ 38
[ 0.381439] pcieport 0000:00:00.0: AER: enabled with IRQ 38
[ 0.381505] rp1 0000:01:00.0: bar0 len 0x4000, start 0x1f00410000, end 0x1f00413fff, flags, 0x40200
[ 0.381510] rp1 0000:01:00.0: bar1 len 0x400000, start 0x1f00000000, end 0x1f003fffff, flags, 0x40200
[ 0.381519] rp1 0000:01:00.0: enabling device (0000 -> 0002)
[ 0.382138] rp1 0000:01:00.0: chip_id 0x20001927
[ 0.386317] genirq: irq_chip rp1_irq_chip did not update eff. affinity mask of irq 100
[ 0.403188] macb 1f00100000.ethernet eth0: Cadence GEM rev 0x00070109 at 0x1f00100000 irq 106 (2c:cf:67:36:83:b3)
[ 0.403934] dw_axi_dmac_platform 1f00188000.dma: DesignWare AXI DMA Controller, 8 channels
[ 0.404123] xhci-hcd xhci-hcd.0: xHCI Host Controller
[ 0.404131] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 1
[ 0.404572] xhci-hcd xhci-hcd.0: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000008000000810
[ 0.404582] xhci-hcd xhci-hcd.0: irq 131, io mem 0x1f00200000
[ 0.404643] xhci-hcd xhci-hcd.0: xHCI Host Controller
[ 0.404647] xhci-hcd xhci-hcd.0: new USB bus registered, assigned bus number 2
[ 0.404651] xhci-hcd xhci-hcd.0: Host supports USB 3.0 SuperSpeed
[ 0.404706] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 0.404711] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.404714] usb usb1: Product: xHCI Host Controller
[ 0.404717] usb usb1: Manufacturer: Linux 6.6.74+rpt-rpi-2712 xhci-hcd
[ 0.404719] usb usb1: SerialNumber: xhci-hcd.0
[ 0.404811] hub 1-0:1.0: USB hub found
[ 0.404825] hub 1-0:1.0: 2 ports detected
[ 0.404925] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 0.404929] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.404932] usb usb2: Product: xHCI Host Controller
[ 0.404934] usb usb2: Manufacturer: Linux 6.6.74+rpt-rpi-2712 xhci-hcd
[ 0.404937] usb usb2: SerialNumber: xhci-hcd.0
[ 0.404993] hub 2-0:1.0: USB hub found
[ 0.405004] hub 2-0:1.0: 1 port detected
[ 0.405201] xhci-hcd xhci-hcd.1: xHCI Host Controller
[ 0.405206] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 3
[ 0.405640] xhci-hcd xhci-hcd.1: hcc params 0x0240fe6d hci version 0x110 quirks 0x0000008000000810
[ 0.405651] xhci-hcd xhci-hcd.1: irq 136, io mem 0x1f00300000
[ 0.405703] xhci-hcd xhci-hcd.1: xHCI Host Controller
[ 0.405706] xhci-hcd xhci-hcd.1: new USB bus registered, assigned bus number 4
[ 0.405710] xhci-hcd xhci-hcd.1: Host supports USB 3.0 SuperSpeed
[ 0.405738] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.06
[ 0.405742] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.405746] usb usb3: Product: xHCI Host Controller
[ 0.405748] usb usb3: Manufacturer: Linux 6.6.74+rpt-rpi-2712 xhci-hcd
[ 0.405751] usb usb3: SerialNumber: xhci-hcd.1
[ 0.405824] hub 3-0:1.0: USB hub found
[ 0.405835] hub 3-0:1.0: 2 ports detected
[ 0.405913] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.06
[ 0.405917] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.405920] usb usb4: Product: xHCI Host Controller
[ 0.405923] usb usb4: Manufacturer: Linux 6.6.74+rpt-rpi-2712 xhci-hcd
[ 0.405925] usb usb4: SerialNumber: xhci-hcd.1
[ 0.405987] hub 4-0:1.0: USB hub found
[ 0.405997] hub 4-0:1.0: 1 port detected
[ 0.406498] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[ 0.406729] platform 1000800000.codec: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[ 0.406734] platform 1000800000.codec: bcm2712_iommu_device_group: MMU 1000005100.iommu
[ 0.406739] platform 1000800000.codec: Adding to iommu group 0
[ 0.406746] platform 1000880000.pisp_be: bcm2712_iommu_probe_device: MMU 1000005100.iommu
[ 0.406750] platform 1000880000.pisp_be: bcm2712_iommu_device_group: MMU 1000005100.iommu
[ 0.406755] platform 1000880000.pisp_be: Adding to iommu group 0
[ 0.406773] platform 1000800000.codec: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[ 0.406777] platform 1000880000.pisp_be: bcm2712_iommu_attach_dev: MMU 1000005100.iommu
[ 0.406781] bcm2712-iommu 1000005100.iommu: bcm2712_iommu_probe: Success
[ 0.407028] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[ 0.407251] platform axi:gpu: bcm2712_iommu_probe_device: MMU 1000005200.iommu
[ 0.407255] platform axi:gpu: bcm2712_iommu_device_group: MMU 1000005200.iommu
[ 0.407260] platform axi:gpu: Adding to iommu group 1
[ 0.407276] platform axi:gpu: bcm2712_iommu_attach_dev: MMU 1000005200.iommu
[ 0.407280] bcm2712-iommu 1000005200.iommu: bcm2712_iommu_probe: Success
[ 0.407502] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_init: DEBUG_INFO = 0x20804774
[ 0.407718] bcm2712-iommu 1000005280.iommu: bcm2712_iommu_probe: Success
[ 0.407966] sdhci-brcmstb 1000fff000.mmc: Got CD GPIO
[ 0.408051] mmc0: CQHCI version 5.10
[ 0.408504] of_cfs_init
[ 0.408541] of_cfs_init: OK
[ 0.408610] clk: Disabling unused clocks
[ 0.441237] mmc0: SDHCI controller on 1000fff000.mmc [1000fff000.mmc] using ADMA 64-bit
[ 0.441344] Waiting for root device PARTUUID=617f9ab6-02...
[ 0.539115] mmc0: new ultra high speed DDR50 SDHC card at address 59b4
[ 0.539331] mmcblk0: mmc0:59b4 USD 7.47 GiB
[ 0.540965] mmcblk0: p1 p2
[ 0.541052] mmcblk0: mmc0:59b4 USD 7.47 GiB
[ 0.560233] EXT4-fs (mmcblk0p2): INFO: recovery required on readonly filesystem
[ 0.560238] EXT4-fs (mmcblk0p2): write access will be enabled during recovery
[ 0.661237] usb 3-1: new high-speed USB device number 2 using xhci-hcd
[ 0.813138] usb 3-1: New USB device found, idVendor=152a, idProduct=8750, bcdDevice= 0.39
[ 0.813143] usb 3-1: New USB device strings: Mfr=1, Product=3, SerialNumber=0
[ 0.813146] usb 3-1: Product: D90 III Discrete
[ 0.813148] usb 3-1: Manufacturer: Topping
[ 0.885797] input: Topping D90 III Discrete as /devices/platform/axi/1000120000.pcie/1f00300000.usb/xhci-hcd.1/usb3/3-1/3-1:1.3/0003:152A:8750.0001/input/input0
[ 0.885849] hid-generic 0003:152A:8750.0001: input,hidraw0: USB HID v1.10 Device [Topping D90 III Discrete] on usb-xhci-hcd.1-1/input3
[ 1.836129] EXT4-fs (mmcblk0p2): recovery complete
[ 1.840739] EXT4-fs (mmcblk0p2): mounted filesystem 3a141a28-1a5e-4507-812e-0611f45be6a4 ro with ordered data mode. Quota mode: none.
[ 1.840756] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.842493] devtmpfs: mounted
[ 1.845118] Freeing unused kernel memory: 5120K
[ 1.845162] Run /sbin/init as init process
[ 1.845164] with arguments:
[ 1.845165] /sbin/init
[ 1.845166] with environment:
[ 1.845166] HOME=/
[ 1.845167] TERM=linux
[ 2.204430] systemd[1]: System time before build time, advancing clock.
[ 2.289663] NET: Registered PF_INET6 protocol family
[ 2.290019] Segment Routing with IPv6
[ 2.290029] In-situ OAM (IOAM) with IPv6
[ 2.330996] systemd[1]: systemd 252.36-1~deb12u1 running in system mode (+PAM +AUDIT +SELINUX +APPARMOR +IMA +SMACK +SECCOMP +GCRYPT -GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBFDISK +PCRE2 -PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD -BPF_FRAMEWORK -XKBCOMMON +UTMP +SYSVINIT default-hierarchy=unified)
[ 2.331018] systemd[1]: Detected architecture arm64.
[ 2.339430] systemd[1]: Hostname set to <DietPi63>.
[ 2.710457] systemd[1]: Queued start job for default target graphical.target.
[ 2.735232] systemd[1]: Created slice system-getty.slice - Slice /system/getty.
[ 2.737975] systemd[1]: Created slice system-modprobe.slice - Slice /system/modprobe.
[ 2.740345] systemd[1]: Created slice system-systemd\x2dfsck.slice - Slice /system/systemd-fsck.
[ 2.742438] systemd[1]: Created slice user.slice - User and Session Slice.
[ 2.743015] systemd[1]: Started systemd-ask-password-console.path - Dispatch Password Requests to Console Directory Watch.
[ 2.743517] systemd[1]: Started systemd-ask-password-wall.path - Forward Password Requests to Wall Directory Watch.
[ 2.744126] systemd[1]: Set up automount proc-sys-fs-binfmt_misc.automount - Arbitrary Executable File Formats File System Automount Point.
[ 2.744216] systemd[1]: Expecting device dev-disk-by\x2dpartuuid-617f9ab6\x2d01.device - /dev/disk/by-partuuid/617f9ab6-01...
[ 2.744271] systemd[1]: Reached target cryptsetup.target - Local Encrypted Volumes.
[ 2.744329] systemd[1]: Reached target integritysetup.target - Local Integrity Protected Volumes.
[ 2.744395] systemd[1]: Reached target paths.target - Path Units.
[ 2.744439] systemd[1]: Reached target remote-fs.target - Remote File Systems.
[ 2.744481] systemd[1]: Reached target slices.target - Slice Units.
[ 2.744525] systemd[1]: Reached target swap.target - Swaps.
[ 2.744573] systemd[1]: Reached target veritysetup.target - Local Verity Protected Volumes.
[ 2.744756] systemd[1]: Listening on systemd-fsckd.socket - fsck to fsckd communication Socket.
[ 2.744848] systemd[1]: Listening on systemd-initctl.socket - initctl Compatibility Named Pipe.
[ 2.745107] systemd[1]: Listening on systemd-journald-audit.socket - Journal Audit Socket.
[ 2.745261] systemd[1]: Listening on systemd-journald-dev-log.socket - Journal Socket (/dev/log).
[ 2.745409] systemd[1]: Listening on systemd-journald.socket - Journal Socket.
[ 2.746379] systemd[1]: Listening on systemd-udevd-control.socket - udev Control Socket.
[ 2.746498] systemd[1]: Listening on systemd-udevd-kernel.socket - udev Kernel Socket.
[ 2.746657] systemd[1]: dev-hugepages.mount - Huge Pages File System was skipped because of an unmet condition check (ConditionPathExists=/sys/kernel/mm/hugepages).
[ 2.747629] systemd[1]: Mounting dev-mqueue.mount - POSIX Message Queue File System...
[ 2.748820] systemd[1]: Mounting sys-kernel-debug.mount - Kernel Debug File System...
[ 2.750175] systemd[1]: Mounting sys-kernel-tracing.mount - Kernel Trace File System...
[ 2.752777] systemd[1]: Starting fake-hwclock.service - Restore / save the current clock...
[ 2.754702] systemd[1]: Starting keyboard-setup.service - Set the console keyboard layout...
[ 2.755971] systemd[1]: Starting kmod-static-nodes.service - Create List of Static Device Nodes...
[ 2.757499] systemd[1]: Starting
[email protected] - Load Kernel Module configfs...
[ 2.759092] systemd[1]: Starting modprobe@dm_mod.service - Load Kernel Module dm_mod...
[ 2.760947] systemd[1]: Starting
[email protected] - Load Kernel Module drm...
[ 2.762751] systemd[1]: Starting modprobe@efi_pstore.service - Load Kernel Module efi_pstore...
[ 2.764496] systemd[1]: Starting
[email protected] - Load Kernel Module fuse...
[ 2.766299] systemd[1]: Starting
[email protected] - Load Kernel Module loop...
[ 2.768250] systemd[1]: Starting systemd-fsck-root.service - File System Check on Root Device...
[ 2.770586] systemd[1]: Starting systemd-journald.service - Journal Service...
[ 2.807140] device-mapper: ioctl: 4.48.0-ioctl (2023-03-01) initialised:
[email protected]
[ 2.817425] fuse: init (API version 7.39)
[ 2.821483] systemd[1]: Starting systemd-modules-load.service - Load Kernel Modules...
[ 2.823468] systemd[1]: Starting systemd-udev-trigger.service - Coldplug All udev Devices...
[ 2.826375] systemd[1]: Mounted dev-mqueue.mount - POSIX Message Queue File System.
[ 2.826615] systemd[1]: Mounted sys-kernel-debug.mount - Kernel Debug File System.
[ 2.826780] systemd[1]: Mounted sys-kernel-tracing.mount - Kernel Trace File System.
[ 2.827186] systemd[1]: Finished kmod-static-nodes.service - Create List of Static Device Nodes.
[ 2.827725] systemd[1]:
[email protected]: Deactivated successfully.
[ 2.827942] systemd[1]: Finished
[ 2.828396] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 2.828616] systemd[1]: Finished modprobe@dm_mod.service - Load Kernel Module dm_mod.
[ 2.829068] systemd[1]: modprobe@efi_pstore.service: Deactivated successfully.
[ 2.829329] systemd[1]: Finished modprobe@efi_pstore.service - Load Kernel Module efi_pstore.
[ 2.829741] systemd[1]:
[ 2.830009] systemd[1]: Finished
[ 2.830438] systemd[1]:
[ 2.830635] systemd[1]: Finished
[ 2.832959] systemd[1]: Mounting sys-fs-fuse-connections.mount - FUSE Control File System...
[ 2.834962] systemd[1]: Mounting sys-kernel-config.mount - Kernel Configuration File System...
[ 2.837120] systemd[1]: Started systemd-fsckd.service - File System Check Daemon to report status.
[ 2.838128] systemd[1]: systemd-repart.service - Repartition Root Disk was skipped because no trigger condition checks were met.
[ 2.839176] systemd[1]: Mounted sys-fs-fuse-connections.mount - FUSE Control File System.
[ 2.839584] systemd[1]: Mounted sys-kernel-config.mount - Kernel Configuration File System.
[ 2.845859] systemd[1]: Started systemd-journald.service - Journal Service.
[ 3.071163] EXT4-fs (mmcblk0p2): re-mounted 3a141a28-1a5e-4507-812e-0611f45be6a4 r/w. Quota mode: none.
[ 3.441429] rpi-gpiomem 107d508500.gpiomem: window base 0x107d508500 size 0x00000040
[ 3.441802] rpi-gpiomem 107d508500.gpiomem: initialised 1 regions as /dev/gpiomem1
[ 3.441949] rpi-gpiomem 107d517c00.gpiomem: window base 0x107d517c00 size 0x00000040
[ 3.442746] rpi-gpiomem 107d517c00.gpiomem: initialised 1 regions as /dev/gpiomem2
[ 3.442831] rpi-gpiomem 107d504100.gpiomem: window base 0x107d504100 size 0x00000020
[ 3.443152] rpi-gpiomem 107d504100.gpiomem: initialised 1 regions as /dev/gpiomem3
[ 3.443270] rpi-gpiomem 107d510700.gpiomem: window base 0x107d510700 size 0x00000020
[ 3.443591] rpi-gpiomem 107d510700.gpiomem: initialised 1 regions as /dev/gpiomem4
[ 3.443939] rpi-gpiomem 1f000d0000.gpiomem: window base 0x1f000d0000 size 0x00030000
[ 3.444765] rpi-gpiomem 1f000d0000.gpiomem: initialised 1 regions as /dev/gpiomem0
[ 3.480817] brcmstb-i2c 107d508200.i2c: @97500hz registered in interrupt mode
[ 3.481020] brcmstb-i2c 107d508280.i2c: @97500hz registered in interrupt mode
[ 3.489023] input: pwr_button as /devices/platform/pwr_button/input/input1
[ 3.503733] [drm] Initialized v3d 1.0.0 20180419 for 1002000000.v3d on minor 0
[ 3.529335] mc: Linux media interface: v0.10
[ 3.574365] videodev: Linux video capture interface: v2.00
[ 3.640430] pispbe 1000880000.pisp_be: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[ 3.641539] pispbe 1000880000.pisp_be: Runtime PM usage count underflow!
[ 3.656379] rpivid_hevc: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.656952] rpivid 1000800000.codec: bcm2712_iommu_of_xlate: MMU 1000005100.iommu
[ 3.658004] rpivid 1000800000.codec: Device registered as /dev/video19
[ 3.714336] usb 3-1: Warning! Unlikely big volume range (=2032), cval->res is probably wrong.
[ 3.714344] usb 3-1: [10] FU [D90 III Discrete Playback Volume] ch = 2, val = -32512/0/16
[ 3.717401] usb 3-1: Warning! Unlikely big volume range (=2032), cval->res is probably wrong.
[ 3.717405] usb 3-1: [10] FU [D90 III Discrete Playback Volume] ch = 1, val = -32512/0/16
[ 3.717947] usbcore: registered new interface driver snd-usb-audio
[ 3.732255] vc4-drm axi:gpu: bcm2712_iommu_of_xlate: MMU 1000005200.iommu
[ 3.734445] vc4-drm axi:gpu: bound 107c580000.hvs (ops vc4_hvs_ops [vc4])
[ 3.738752] Registered IR keymap rc-cec
[ 3.738792] rc rc0: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0
[ 3.738839] input: vc4-hdmi-0 as /devices/platform/soc/107c701400.hdmi/rc/rc0/input2
[ 3.740504] input: vc4-hdmi-0 HDMI Jack as /devices/platform/soc/107c701400.hdmi/sound/card1/input3
[ 3.741745] vc4-drm axi:gpu: bound 107c701400.hdmi (ops vc4_hdmi_ops [vc4])
[ 3.743085] Registered IR keymap rc-cec
[ 3.743137] rc rc1: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1
[ 3.743185] input: vc4-hdmi-1 as /devices/platform/soc/107c706400.hdmi/rc/rc1/input4
[ 3.744798] input: vc4-hdmi-1 HDMI Jack as /devices/platform/soc/107c706400.hdmi/sound/card2/input5
[ 3.746230] vc4-drm axi:gpu: bound 107c706400.hdmi (ops vc4_hdmi_ops [vc4])
[ 3.746467] vc4-drm axi:gpu: bound 107c500000.mop (ops vc4_txp_ops [vc4])
[ 3.746559] vc4-drm axi:gpu: bound 107c501000.moplet (ops vc4_txp_ops [vc4])
[ 3.746624] vc4-drm axi:gpu: bound 107c410000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 3.746690] vc4-drm axi:gpu: bound 107c411000.pixelvalve (ops vc4_crtc_ops [vc4])
[ 3.748227] [drm] Initialized vc4 0.0.0 20140616 for axi:gpu on minor 1
[ 3.752463] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[ 3.756426] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[ 3.763556] vc4-drm axi:gpu: [drm] Cannot find any crtc or sizes
[ 3.889799] systemd-journald[123]: Received client request to flush runtime journal.
[ 4.477279] rp1-firmware: probe of rp1_firmware failed with error -110
[ 5.501280] rp1-pio: probe of 1f00178000.pio failed with error -110
[ 5.713486] macb 1f00100000.ethernet eth0: PHY [1f00100000.ethernet-ffffffff:01] driver [Broadcom BCM54213PE] (irq=POLL)
[ 5.713519] macb 1f00100000.ethernet eth0: configuring for phy/rgmii-id link mode
[ 5.716746] pps pps0: new PPS source ptp0
[ 5.717541] macb 1f00100000.ethernet: gem-ptp-timer ptp clock registered.
[ 9.823385] macb 1f00100000.ethernet eth0: Link is Up - 1Gbps/Full - flow control off
[ 17.131098] Initializing XFRM netlink socket
[ 18.181696] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.>
- Rich
