Cahudson42
- Joined
- Sep 21, 2019
- Messages
- 1,083
- Likes
- 1,557
Read everything I could find - still confused. Let's go with an example: the 2019 Fire 7" tablet - $30 on sale. Measure the 3.5mm output @ 60hz. 33 ohm load. Anemic. 0.16 v at full volume. Ok. No problem adding something like the NX 3 with my HE 400i. But should I go with a simple amp like the NX3? Or bypass the internal DAC with a DAC/Amp combo?
Using Amazon Music HD it reports the internal DAC as 24/48. Sounds good to me.
I try an es100 and Fiio BTR 3, not in bt, but USB. I can get neither to work. Audio to the tablet shuts off with the es100, and the track selection works, but no sound whatever from HP. (Help appreciated here!) BTR3 worse - audio still coming from tablet..
So my question is - is it really worth it to keep fighting to bypass the internal DAC? How bad is it?? Where do I find measurements for it's DAC performance? (Amp performance irrelevant to me. I will add an external amp anyway..)
All thoughts, suggestions, 'educational references' - whatever, greatly appreciated!
Chris
Chris
