2.4ghz won't fix it. GSM and CDMA run at 800mhz, 850MHz, and 1900MHz if it's your mobile signal that's setting it off. You have to shield it unless it's your cable connectors that's picking it up. If you have a different set of cables with well shielded connectors, about the only easy solution. If it's a stack maybe put the amp or the DAC on top to see if one can shield the other that's getting the interference. These are the beefy 12 gauge
RCA's I use and never had any interference with them (or felt I overpaid).
