Recordings done.
www.dropbox.com
These are large FLAC files. Each is a 24/96 recording. I have not trimmed the silences at the start and end of the FLAC files. When trimmed, there will be 64 mins of audio.
I played the same physical CD in all three sessions, without moving or reconfiguring anything in between. I configured Audacity to record samples in 24-bit integer instead of 32-bit floating point.
There are two recordings of Player B, because this player offers two digital filter settings. I can't hear any difference between these filter settings.
I had earlier posted a link here to the original set of FLAC files which I have used. When burning the CS, I saw free space, so I added a couple of longer tracks at the end. Therefore the set of original FLAC files does not have these last two tracks. In any case the comparison can be done now, because the CD played through the different players is consistent.
I have done zero post-processing. I have not changed the gain, and therefore the tracks are not level matched. The two recordings from Player B are expected to be at identical levels, but the Player A track is expected to be (slightly) different.
I strongly suggest that you don't come to a conclusion about subjective differences until you check them out with IEMs or good clean monitoring headphones.
