feralhogs
- Joined
- Sep 29, 2026
- Messages
- 2
- Likes
- 0
Setting up a pair of JBL 4312Gs in a 15' x 12' x 8' room for daily listening and music production. I need an amp and a sub, under $2k combined, used is fine. I'm buying a UMIK-1 and will measure with REW, and I'm open to DSP and room EQ.
Current signal chain is PC > Scarlett 2i2 3rd gen, 2 balanced TRS outs.
Questions!
Thank you all in advance! So, so excited to plug my new speakers in and upgrade from my KRK Rokit 3s!!!
Questions!
- Amp: which well-measured amps have plenty of headroom for these speakers? I listen loud and don't need features.
- Sub: fast, low-distortion options in budget that have measurement data. Music ranges from hip-hop to ambient.
- Bass management: run the 4312Gs full range with the sub underneath, or high-pass them and give the low end to the sub? No strong opinion yet. My intuition says full range, but I'd like to hear the tradeoffs for mixing accuracy specifically.
- Where to put the crossover and EQ: the 2i2's limited outputs are the constraint. Would a miniDSP-type box (e.g., 2x4 HD) between the interface and the amp and sub be worth the money compared with using the sub's built-in DSP?
