Hello all,
Please feel free to shoot me if this post is not meant to be here, only my second post, so won't be offended at all
Now, I have the following kit which I intend to use for both listening in stereo & movies in surround sound.
Speakers: B&W 702 S3 Fronts
B&W 705 S3 Surrounds
Subwoofer: B&W DB1D
AVR: Denon X6400H
DAC: Benchmark DAC3 HGC
Amp: Benchmark AHB2
Turntable: Rega P8
Now for 2 channel listening, I use the DAC as the preamp to which all my digital & analog inputs are connected and I use the XLR outputs to get the analog signal out to the AHB2.
At the moment, I hooked up the DB1D sub to the DAC with the two RCA outs on the DAC, however, since there is no bass management on the DAC, the sub is receiving a full signal similar to the fronts which makes the bass sound muddy.
Also, since I want the Denon to pass the LFE during movies, I'll have to unplug one of the RCA cables from the DAC and connect it to the Denon's LFE out when playing movies, which I would like to avoid if possible.
I've learnt that integrating a miniDSP into the setup should allow me to integrate the subwoofer into the 2 channel listening scenario. This is where my confusion starts.
Assuming integrating a miniDSP is the way to go (but please shout if there's other ways particularly if I can get it from my already existing gear), I have looked at miniDSP SHD Studio, Flex & the full Studio versions and below are my thoughts -
SHD Studio - this has only digital I/O - I can switch to the Studio as the preamp and connect all my digital inputs to it, instead of my DAC, happy days, but it doesn't have analog inputs for my turntable.
SHD Flex - this has digital I/O & analog inputs - which I think is the one that suits my requirement because I can connect all my digital and analog inputs. I connect it before the DAC so that D/A conversion only happens in my Benchmark DAC which is my preferred option, however, since this doesn't have any analog outputs, I may have to add another DAC to take the digital signal from let's say channel 3&4 and send it to this new DAC which will inturn be connected to my subwoofer. If you agree with this, please suggest a good DAC that has XLR outputs because the RCA inputs on the subwoofer will be connected to the Denon which only leaves XLR inputs on the sub available for use.
SHD Full version - this has a plethora of I/O, however, I feel that it's overkill or not suitable for my scenario. For eg: I don't need the XLR inputs or outputs since I'm not planning to use the DAC component in the SHD which means this needs to be before my DAC (so similar to the Flex, all my digital& analog (via RCA) inputs will be connected to it and I plan to take the digital signal out from the SHD and into the Benchmark DAC. So, unless the SHD can output both a digital signal (forthe Benchmark DAC) and an analog signal (for the subwoofer without an additional DAC) at the same time, this doesn't seem to fit my purpose.
Please can you evaluate the above and let me know if there is an alternate option or if there is a preferred option from the above. I mean for eg: instead of going for a Flex and a separate DAC for the sub, I could go with the Full version if the cost at the end is the same since it prevents more components to be added and even perhaps comes with a DIRAC licence which I presume the FLEX wouldn't come with (can always upgrade though).
Also, is there anything I could be missing out if going for a relatively cheaper option like the Flex for example in terms of the quality of processing etc?
Thanks,
Jay
Subwoofer: B&W DB1D
AVR: Denon X6400H
Amp: Benchmark AHB2
Turntable: Rega P8
Thanks,
Jay
