JSmith
Thanks for that info, appreciated.The Citation Amp is based on the Axign chip.
Seems it's not available anyway until July. Still if it measures well this may be a great option for many.
JSmith
.....They are just as secretive with their tech info.
I cannot find a NAD M3, did you mean M33? If so that is four times the budget.My NAD M3 has a hardware crossover that while not fully flexible in terms of micro adjustment does allow me to send the mains nothing below 40Hz in my case and then from the same preout section my two subs are sent the full signal to be adjusted at the sub. Not sure if the M3 would be a suitable recommendation, but for my 2.2 system it works quite well or perhaps I just don't know the difference. In either case I am content.
No, and my apology for adding noise to your thread. The M3 is discontinued, but it comes up used and is worth considering. It is an exceptional NAD design based on both subjective and objective reviews and it is built like a tank. I think it weighs about 65lbs. I shouldn't have polluted your thread mate, I did want to mention the M3 as NAD really did themselves proud with it and it can be found used for good prices, at least here in North America. I see it used from time to time. I actually bought mine used and have never regretted it. I actually use it as my headphone amplifier as I had some nice speaker tap cables made that allow me to drive headphones right from the speaker terminals.I cannot find a NAD M3, did you mean M33? If so that is four times the budget.
No need to apologise. Your input is appreciated by me. Can you point me to a page where I can learn more of the NAD M3?
Hi
On the Emotiva speaker review thread a discussion has started on the availability of integrated stereo amplifier with bass-management and subwoofer output that will allow small speakers to be used with a subwoofer? Sometimes this is called a 2.1 setup.
The requirements are:
Bonus features:
- A one unit solution as in "integrated"
- Good amplification suitable for Hi-Fi usage
- Physical volume control and not depending on an app to use it.
- At least one analogue input
- Integrated crossover to use with a subwoofer
- At least one analogue subwoofer output
- Adjustable subwoofer crossover frequency.
- Cost no more than US$1000 or thereabouts
- Available to the UK
Not acceptable are:
- Small size as they will be used with small speakers which are often used in confined spaces.
- Adjustable subwoofer crossover slope
- Wireless streaming
- Roon endpoint
So far the following mentioned. All failed to satisfy the above criteria other than the ELAC (last item). I am trying to find out what else is out there.
- An AVR
- Any internal video circuity
- https://usa.yamaha.com/products/audio_visual/hifi_components/r-n803/index.html
- https://www.denon.com/en-us/product/amplifiers/heos-amp
- https://www.parasound.com/200_Integrated.php
- https://www.parasound.com/hint6.php
- https://www.sonos.com/en-us/shop/amp.html
- https://outlawaudio.com/shop/stereo-receivers/56-rr2160mkii-stereo-receiver.html
- https://www.elac.com/home-theater-amplifiers/discovery-series-dsa101-g/
People on the above referenced forum swear by this 2.1 solution, which has even a THX standard attached to it but other than an AVR I can see just one suitable integrated amplifier. What am I missing?
Thank you in advance for your suggestions.
This is a good review with measurements as well.No need to apologise. Your input is appreciated by me. Can you point me to a page where I can learn more of the NAD M3?
Do you mind explaining what you mean by that?BHopefully I've managed to stick to the specs of the borderline intolerable OP.
Thank you. It looks like it is an all analogue unit.
I wonder should we tell the "reviewer" what midrange he had in mind which can operate down to 100Hz“Biamp” (uses selectable crossover frequencies of 40 Hz, 60 Hz, 80 Hz, or 100 Hz, if you want to drive the tweeter and midrange driver of a speaker with one of the power amplifiers, and the woofer with the other channel)
Nope. If you are willing to pay double my budget there are some options.Hey! Just wondering if you found any more options that fit your requirements?
It's baffling to see manufacturers offer amplifiers with alleged "sub outs" without making it clear if you can set a crossover or if just sends the full signal to speakers and subs.
When was the last time you had access to a manual at the dealer/shop or at an ecommerce site?Usually looking at the manual will make that clear one way or the other....
