- Joined
- Jun 10, 2018
- Messages
- 6,192
- Likes
- 9,291
You sure are playing your cards close to your chest. I can't help you without more information.There is nothing wrong with Elac. I clearly said "I am trying to find out what else is out there. "
What gave you the idea that I am playing a game? I listed clear specifications. I said I found just one unit (Elac) that qualifies and asked if there any others in the market.You sure are playing your cards close to your chest. I can't help you without more information.
At this point I don't want to know anything about you or what you want.What gave you the idea that I am playing a game? I listed clear specifications. I said I found just one unit (Elac) that qualifies and asked if there any others in the market.
How open do you want me to get? What else do you want to know?
I am not asking advice on how to use something, or what to use. I am asking information about devices that fit a specification.
So why not and AVR? The economies of scare outweigh paying for features you won't use. People swear the earth is flat. There isn't a lot of demand for a 2.1 system, obviously. Purist don't want it and others just use an AVR.Hi
On the Emotiva speaker review thread a discussion has started on the availability of integrated stereo amplifier with bass-management and subwoofer output that will allow small speakers to be used with a subwoofer? Sometimes this is called a 2.1 setup.
The requirements are:
Bonus features:
- A one unit solution as in "integrated"
- Good amplification suitable for Hi-Fi usage
- Physical volume control and not depending on an app to use it.
- At least one analogue input
- At least one analogue subwoofer output
- Adjustable subwoofer crossover frequency.
- Cost no more than US$1000 or thereabouts
- Available to the UK
Not acceptable are:
- Small size as they will be used with small speakers which are often used in confined spaces.
- Adjustable subwoofer crossover slope
- Wireless streaming
- Roon endpoint
So far the following mentioned. All failed to satisfy the above criteria other than the ELAC (last item). I am trying to find out what else is out there.
- An AVR
- No video circuity
- https://usa.yamaha.com/products/audio_visual/hifi_components/r-n803/index.html
- https://www.denon.com/en-us/product/amplifiers/heos-amp
- https://www.parasound.com/200_Integrated.php
- https://www.parasound.com/hint6.php
- https://www.sonos.com/en-us/shop/amp.html
- https://outlawaudio.com/shop/stereo-receivers/56-rr2160mkii-stereo-receiver.html
- https://www.elac.com/home-theater-amplifiers/discovery-series-dsa101-g/
People on the above referenced forum swear by this 2.1 solution, which has even a THX standard attached to it but other than an AVR I can see just one suitable integrated amplifier. What am I missing?
Thank you in advance for your suggestions.
Because we can be more helpful if we know what goal you want to achieve and what is your use case. There are many ways to set up a stereo system with bass-management, and not knowing why you have excluded some of them does not help the discussion.Why would a science orientated forum member insist that I change my specs. Can't they accept that a fellow forum is doing this as a research for reasons of his own? Why do they want to know his reasoning?
I think I'm not alone sensing a slightly defensive attitude. Being straight to the point doesn't mean that we can't add a bit of tact in the mix.It seems so, but how am I supposed to know that if I do not research for it? Is it forbidden or not cool to do research in this forum?
I am a complete loss at the reaction I get here. I am trying to be objective in my selection of device. Should one must take advice, which is almost always subjective on what fits what? Can't I make my own mind in selecting what to use?
I am asking in a audio forum if there are any devices that match my specs. It is as simple as that. If what I am looking doesn't exist, in a mature industry as Hi-Fi, most likely there is no market for it. And, I will know.
+1I think I'm not alone sensing a slightly defensive attitude. Being straight to the point doesn't mean that we can't add a bit of tact in the mix.
No you didn't. You said that what was not acceptable was 'no video circuitry'. You said the opposite.I do not want video circuity. I think I made it clear from the onset.
Besides, it doesn't have variable xover frequency.
I apologise for making a grammar mistake. I can see that now. I should have said "video circuity". I will correct it if I can.No you didn't. You said that what was not acceptable was 'no video circuitry'. You said the opposite.
I was no way endorsing Elac nor paying attention to it. I listed as last, just mentioned its name once. I clearly said that I am looking for other units that fit the criteria. In fact after what I read your comments I will reject the Elac unit it as well. UI is a very important element of any device.The Elac seems to fit your bill, and considering that your requirements are very specific and not common, it seems fortuitous that there is even one component that fits your bill. In fact, it almost seems as though you were well aware of the features by which the Elac is unique and wrote the post expressly to draw attention to it. No matter. Personally I don't like it because aesthetics matter to me and I do not like the aesthetics of that unit in the least. And I greatly dislike the idea of a button that you have to repeatedly push to select the input. Push buttons are good for things that have two states, i.e., on and off, not for selecting among multiple choices, and not for adjusting a level via repeated pushing. ...
... I find the OP general demeanor, at least in this thread, rude. I think , I am saying aloud what many are thinking.
The Elac seems to fit your bill, and considering that your requirements are very specific and not common....
Also, other users may be interested in setting up a 2.1 system, but may have different needs or preferences. Opening up the discussion to alternatives may help them as well.
I suppose the dearth of products meeting the specs is proof enough the requirements are not common. I cannot understand why this is so. The benefits of room calibration/bass management are well accepted even by non-audiophiles. The benefits are easily demonstrated on the sales floor, as are the benefits of adding a powered sub. I'm with sarumbear in not understanding why there is not more demand.
I believe the Martin-Logan Forte amp and its near twin Paradigm PW Amp may also meet the OP's specs, although Amir's PW Amp test calls into question whether they have "good amplification". In Amir's "Not Recommended" conclusion he does state: "No doubt room EQ will make a bigger difference than any of these measurements do in the sound of the amplifier. So there is good value there."
I think this is objectively true, which once again brings into question why bass management/room eQ is not common in 2 channel equipment.
Last post on the thread ...
I actually learned from this thread. I would have thought the OP solution to be easy and commonplace. it is not.
I do believe there is a gentler way to express dissent. It could be the OP personal style and In real life, vocal inflexions intonations, body or facial expressions may/could help. Such don't translate well (or at all) in internet fora.
Out.
