Integrated amplifier second hand for B&WCM8 S2
Mortenblist
Hi there
I would really appreciate some help finding a good integrated amplifier for our B&W CM8 S2.
My wife would like it to be not that big especially not tall .
I have the opportunity for buying Audiolab 6000A + the cd player for 5500,- DKK used, but almost new.
I just don’t think it will match.
I really like the Mission 778X, but again - is it too small for the speakers.?
I need the opportunity to play with our turntable.
The room it has to fit in is about 4 X 5 meters, and speakers with about 3 meters in between.
Thanx in advance
Morten from Denmark
How loud are you looking to go? The speakers list 88dB for efficiency so unless you like your ears to bleed they should be pretty easy to power.
I've run my CM5 S2 which are rated about the same off of a 7 watt tube amp and it goes louder than I want most of the time.
tA240 thanx maaan..
Yeah I begin to believe that when I talk to all these stores about matching, I feel it’s getting higher and higher in models.
I’m not gonna listen to that loud music most of the time, but it is nice with the ability once in a while.
Do you need only analog inputs, or digital inputs too... i.e. inbuilt DAC?
If analog only, this may well suffice;
If digital inputs are needed as well, maybe check out the WiiM... but a bit lighter on power output;
JSmith
JSmith
Good suggestion in itself but regarding WiiM Amp Pro remember that TS wrote: I need the opportunity to play with our turntable.
If WiiM Amp Pro is chosen, TS needs to buy an external phone pre amp. And WiiM Amp Pro only has one input, which, if TS or TS family, wants to switch between, for example, streaming and turntable, it becomes cumbersome. In that case, the Yamaha you recommended is a much better choice given its inputs.:)
I wonder if it might not be stressful in the long run for a tube amp because those speakers seem to dip down to 3 Ohms? But if you haven't experienced any problems, you haven't.
Otherwise, I had looked at an amp with the desired functions, inputs (also digital?), maybe remote control around at least 70 watts. Or fewer watts, if it is not played at such a high volume in the TS home.
As TS is thinking about a used one, in that case in that case, I recommend an amp from recognized good brands such as Yamaha or NAD. Class AB amp in that case. Not any old class D amp. New class D, now that the development of class D has progressed, is another matter.:)
Edit:
Here's a tip if TS find an amp that has several inputs but no phono input. Like for example a Nad C325 BEE (basically the same as the Nad 320 that Amir tested, 67 watts when clipping).Here's a fully functional used one for $130, in Denmark:
Then just add this to be able to play vinyl: :)
