Insufficient volume from Topping DX9D when playing classic music
TheHermitViolinist
Good day folk.
I listen to highres FLAC (24/96) from a dedicated windows11 PC connected via USB to a Topping DX9 Discrete and a pair of Sennheiser 660x.
My music taste is 98% classic music, and most of my files are recorded with a relatively low volume, occasionally riddiculously low.
I never have problems when I watch netflix or listen to modern music, but with classic music I find myself lacking in volume, despite selecting the high gain from the DAC/Amp.
In all honesty: the volume is acceptable at maximum, but it makes me wish for more.
I recently upgraded to the DX9 from the Atom Amp+ and that one was significantly more powerful than the current DX9
The question for you then is how I should go by it in the correct way. How do I crank the volume further?
Foobar sends at the maximum volume with no DSP (and obviously no EQ).
The Amp part of my DX9 is already on high gain and I normally enable the EQ with a curve adjusted for my headphones and for slightly warmer sound. The EQ gain is here revised downwards to prevent distortion.
I considered creating a new EQ profile (with a less conservative gain) that I would use only with classic music, but maybe you have something better to offer?
Have I missed out on some important feature of my DX9?
Thanks in advance
There is the free but hard work option of modifying the FLACs to increase the source rather than stacking gains through components. That's safest from the position of not blasting your ears in when you forget to turn it down.
I think it would be labour intensive or require you to start programming to rewrite all the files with volume normalised volume.
You might increase oomph from the DX9 if you're using balanced cabling rather than unbalanced.
Better transducers for your particular amp perhaps. Perhaps simply better transducers.
ReplayGain, definitely. But it’s still a mystery why it sounds louder with your Atom+.
Looking at the specs/measurements, the DX9 has both more power and higher gain than the Atom+, though it’s close in single-ended mode. Are you maybe using PEQ with the DX9 and lopping off a bunch of headroom?
If so, you could get a $20 balanced cable and that should solve the problem.
A balanced connection should go 6dB louder. More analog gain and more available analog peak-power is usually the answer.
You may just need more output from your headphone amp or more sensitive headphones, although what you have is already better than average in that respect.
ReplayGain may help a bit, but classical is still going to be quieter unless you change the defaults and allow ReplayGain to push the peaks into clipping/distortion. And generally, you'd want to use the Album Gain setting to keep quiet and loud tracks/movements with the same relative loudness (one loudness adjustment for the whole performance).
Audacity can normalize ("maximize"), setting the digital peaks to the 0dBFS digital maximum. Again, you'd probably want to normalize the performance as a whole. But a few "loud" peaks don't necessarily sound loud and classical music has a lot of dynamics (loud and quiet parts) so it's never going to sound as loud as a modern production. And it may already be peak-normalized.
Normalizing should be about the same as ReplayGain, since ReplayGain will be boosting these quiet tracks as much as possible without clipping.
The Loudness War is "won" with lots of dynamic compression and that's not how classical music is supposed to sound. (A lot of us don't like what it does to rock either...)
Good day folk.
Thanks in advance
You may have overlooked the fact that the power output of the DX9 D headphone amplifier at its unbalanced output at 300 ohms isn't actually much higher than that of the Atom Amp+ (approximately 270 mW vs. 260 mW).
However, at lower impedances, the DX9 D is significantly superior (32 ohms: 1 W vs. 2.1 W).
With a balanced headphone cable, this power output at 300 ohms increases by a factor of approximately four to around 1060 mW.
Power shouldn’t matter because the signal is low. Gain matters, where the DX9 is supposed to have +20dB in high gain single ended, vs the Atom Amp’s +13dB.
My guess is PEQ.
There are several models with similar names. Are these HD 660X, 660S, or HD 6XX?
I should have written HD6xx.
I was reluctant in boosting the gain from the PEQ equaliser for fear it would lead to distortion or clipping, but replaygain is a great option for me! Thanks :)
With regards to the difference between the Atom and the DX9: first of all I don't (yet) use a balanced cable; secondly I enabled the PEQ on the DX9 whereas on the Atom the signal was always clean. When I enable the PEQ and boost some frequencies the reccomended gain lowers, and indeed, if I disable the PEQ I get a signal boost. But my ultimate goal was to not induce distortion or clipping with the PEQ enabled.
I did not know that balanced cables gave such a large boost! With an inaudible noise floor on the DX9 I really had difficuly justifying the investment, but now I am intrigued so I will buy that as well.
The solution with replaygain insures that I can use the PEQ with the appropriate gain which scales dynamically based on the track, which is ultimately what I needed!
My guess is PEQ.
You have misread the specs. Single ended high gain maximum output for the DX9 Discrete is 18.5 dBV. Balanced, it is 24.5 dBV. With the typical single ended output DAC output of 6-8 dBV, that is a gain of 10.5 to 12.5 dB single ended and 16.5 to 18.5 dB balanced.
I have listened to plenty of classical music with my HD600 and DX5 II single ended with the same maximum output and have rarely had the need to use high gain. Most times, low gain and -10 dB is the most I needed. Can you give an example of a problematic recording? What DAC did you use before? Do you use exclusive mode in foobar?
Yes, read off the preamp gain rather than the headphone amp gain. Though really it’s close enough.
I’m not sure I understand the second part of what you’re saying, not to say you’re wrong.
You said 20 dB gain. Topping state full scale output in dBV under gain (as indicated by V RMS/FS) not gain relative to line output, which in this case would be 10.5 dB for single ended high gain. Quite different.
Got it. Didn't understand the dBV part so my brain conveniently elided it.
各位好。
我用一台专用的 Windows 11 电脑,通过 USB 连接到 Topping DX9 Discrete 和一副 Sennheiser 660x 耳机,来听高分辨率 FLAC (24/96) 音乐。
我的音乐品味98%是古典音乐,而且我的大部分录音文件音量都比较低,有时甚至低得离谱。
我看 Netflix 或听现代音乐时从来没遇到过问题,但听古典音乐时,即使我选择了 DAC/耳放的高增益,也总是觉得音量不够大。
说实话:最大音量还可以接受,但还是希望音量更大一些。
我最近从Atom Amp+升级到了DX9,Atom Amp+的性能比现在的DX9强得多。
那么问题来了,我应该如何正确地操作?如何才能进一步提高音量?
Foobar 以最大音量发送信号,没有 DSP(当然也没有 EQ)。
我的DX9的放大器部分已经调到高增益,我通常会启用均衡器,并调整曲线以适应我的耳机,使声音略微温暖一些。这里我降低了均衡器的增益,以防止失真。
我考虑过创建一个新的均衡器配置文件(增益设置得不那么保守),专门用于古典音乐,但也许您有更好的建议?
我的DX9是不是漏掉了什么重要功能?
提前致谢
Disable the DSP.
As mentioned, what happens when you run files through FB2K and scan for ReplayGain?
Usually, a reduction in gain is suggested (see the -10.33dB below), but I have seen +5dB occasionally.
What do your FLACs show?
