Input sensitivity match
laidick
hi,
i have hypex NC502MP, the input sensitivity says 2.35Vrms as below:
and the AVM60 XLR output has 8.4Vrms output
would that introduce any clipping if I turn the volume up to reference level?
how should I interpret this number to make sure they match on the same baseline?
Thanks!
SIY
Alfred, NY
The 8.4V is the max level with everything turned up all the way and a full scale signal. As the punchline of the old joke goes, "Don't do that."
IOW, this setup will work fine as is unless you choose to abuse it.
Krunok
Zg, Cro
Can you please help me with similar question?
My amp has input sensitivity of 1V. Room EQ software attenuates input signal by 12dB before the DAC which efectively lowers DAC output, right?
Does this mean that DAC with 2V output will get it's max output lowered to 0.5V due to 12 dB of attenuation?
SIY
Alfred, NY
Can you give some particulars? Especially about the EQ software.
Krunok
Zg, Cro
Not sure why would you need that but here it is: BruteFIR convolution engine that runs on top of Volumio (which feeds the DAC via USB) attenuates input signal by 12dB to avoid clipping due to EQ filters gain. DAC has max output of 2V and amp has input sensitivity of 1V.
Does that mean that even when i crank DAC to the max it won't give more than 0.5V because of 12dB attenuation of the input signal before the DAC?
SIY
Alfred, NY
I asked because I wanted to see if it was EQ software I've used before. I haven't used BruteFIR, so anything I say will be highly speculative. I'm guessing that the 12dB is put on before EQ, so that the EQ has enough headroom- then that 0.5V you're talking about only applies to the parts of the frequency range where there isn't a boost.
Practical answer: can you crank the music loud enough? If so, have a beer.
DonH56
Monument, CO
If it attenuates the input but then adds gain in the EQ after that then it is hard to say the final output level. If EQ adds 12 dB then there is no net change in peak output. I'd guess the attenuation is to allow the EQ to add up to 12 dB of gain (boost) at certain frequencies without changing the peak input level. Back when I was doing digital filters optimizing dynamic range through the filter was a multi-step process as you worked through the various stages to maximize the dynamic range of each without overload. In this case it sounds like they have simplified it by not allowing more than 12 dB of boost anywhere and then attenuating the input by 12 dB to ensure the output never exceeds the input. Hopefully they are monitoring the final signal levels and adjusting the net gain to preserve signal peaks such that a max of say 0 dB in results in 0 dB output.
Note that would be at the frequency with the most boost; other frequencies will be equal or lower.
HTH - Don
Edit: @SIY provide the same answer much more succinctly as I was typing, sorry.
Krunok
Zg, Cro
Ok, everything clear, thank you both! :)
So what will happen in my amp when DAC pushes 2V at it's inputs? Will the clipping occur? Does it depend on the amp design?
DonH56
Monument, CO
Maybe, and yes. Depends on how much headroom has. With 1 V sensitivity and 2 V input that is 6 dB over its rating. Probably clip, at least a little, but some amps design in that much headroom, some don't. If it is too loud turn it down. ;) For noise it is usually better to have higher gain earlier in the chain so I really doubt you'll have problems.
Krunok
Zg, Cro
When I turn off BruteFIR to have full 2V output and crank the power to the max I can't really hear clipping. But maybe I simply can't notice it as the music is so loud I can't leave it on for more than a few seconds as it is quite unpleasant. In other words, I dont' have a real problem, just asking a theoretical question. Thank you both guys, I think I'll now have that beer @SIY mentioned. Cheers!
laidick
laidick
I tested the anthem RCA output and XLR output the same time, when I enable ARC, the left channel has offset +4 to achieve reference 75dB @ -30dBFs with MV= -15.
When I play a pink noise @ 0dBFs, MV -15, the RCA output voltage become 2.6V and XLR has 5.2V. (is it always double ? I am not sure but observed this so far)
Then I have XLR output to nc502mp, where the input sensitivity is 2.35V , will this 5.2V from XLR introduce clipping on the nc502mp module ? How could I tell if I don't have any pro measurement kit?
Thanks!
Cbdb2
Vancouver
Yes, the sensitivity is usually the voltage to get full power, so going over it will clip the amp. First, how are you measuring the voltage? some meters have trouble with measuring noise so a sine might be better. To adjust, feed the dac 0dbfs sine ( 100hz, is good, youtube should have one) and adjust your max level so the amp sees its sensitivity voltage ( Probably RMS ) This assumes that the sensitivity is given in RMS and the amp has no headroom. Then a max source signal should give max power out of the amp with out clipping. And if you want to make sure turn things down a couple db, its seldom good for the sound to drive an amp to just before clipping, and youll barely notice the difference in volume.
RayDunzl
Central Scrutinizer
Riverview FL
If you have both RCA and XLR inputs, set a moderate level of sound using RCA, then swap to XLR.
Guess:
Since the nc502mp does not appear to have differential output, I'd suspect only one leg of the XLR signal is actually used, and you'll hear the same output level, indicating the same input level as RCA.
If it is using all of the differential voltage of the XLR for input, you will hear a 6dB increase in output level, and I'd be unsure of the input condition, though neither leg would exceed specification when referenced to Ground.
Julf
Amsterdam, The Netherlands
Having (or not) a differential output is not really any indication of differential input (or not). All the hypex modules have a true differential input (not referenced to ground).
Julf
Depends on circuit design, but normally yes.
Yes. You can either attenuate the inputs, or modify the nc502mps for lower (6 dB gain) - or simply avoid the last 3 dB of the volume knob.
Studying the specs.
Trustful6061
I have pretty much the same problem as OP but in reverse.
I'm using the infamous Denon X3400H as my pre-amp. According to what I've found, you can't decouple the internal amps with this model and it will limit the "clean" Pre-out voltage range. It seems that the optimal voltage output considering SINAD would be something in the lines of 1.0-1.2 V. Since the NC502MP's input sensitivity is 2.35 V could I estimate that I could get about 50% of the NC502MP's maxmimum output power (without significant losses on the pre-amp's SINAD)? That would mean around 200W@4 ohms/175W@8 ohms. Can the maximum output be "guestimated" like I have or have I misunderstood something? I have absolutely no backround in electrical engineering as you might guess.
Also, is there any other disadvantages when the pre-amp can't perform on the level of power-amp?
Not that the loss in power even matters that much. My speakers are pretty sensitive (based on Eminence Beta CX12 and JBL DT220Ti) and can go to earbleeding levels with very little. I'm mainly intrested in the fact that have I understood these principles somewhat correct and are there some other disadvantages I might have missed.
PS: Sorry for bumping an old thread.
AnalogSteph
.de
If the maximum output voltage is halved, output power is quartered. So you would be getting around 125 W / 4 ohms, or half that into 8 ohms.
Assuming maybe 2 dB for crossover losses, that would put your speakers at about 113 dB SPL / 1 m. Chances are that the drivers and your ears would be complaining before the amplifier does. In fact, you might still find hiss levels to be objectionable enough to warrant attenuation between the pre-outs and power amp, further reducing maximum output.
On an unrelated note, almost all off-the-shelf RCA to XLR adapter cables are problematic as they are not actually making use of the balanced input as such. Good luck trying to avoid ground loop problems when actually trying to combine these components - it would almost invariably involve either some custom-made cables or some line isolators.
Julf
I assume you have seen this?
Julf
That's how I wish they all looked. Instead, 99% of what you're getting is unbalanced and bridging 1 and 3 at the XLR side. :facepalm:
Again showing how a large part of the industry don't understand even the fundamentals of electronics. :(
