Headphonaholic
- Joined
- Apr 8, 2018
- Messages
- 222
- Likes
- 283
Just wanted to create a thread for my impressions of the Hifiman He 560 V2 for anyone that cares. I've only put maybe 2 hours on em so far, so this is very much my first impressions. And for anyone wondering, I'm using March Audio's Dac1 with the Massdrop THX AAA 789 with Tidal.
Build
Anyone familiar with Hifiman knows that they aren't exactly known for their build quality. This headphone sadly isn't an improvement. Oddly enough it seems to be designed for really small heads. I had to extend the adjustments fully to get them to fit my head (I tend to be middle of the road with the headband adjustments on most headphones). The headband adjuster was really tight and difficult to adjust, easily one of Hifiman's worst attempts yet in this area. The headband attaches to what I was hoping was metal but it's actually plastic that upon trying on made some concerning cracking/popping sounds. I do not expect this to last long in this area. The cables are also quite thick and have apparently been coiled for a while since they don't really want to uncoil (anyone familiar with Zeos can just think back to any of his cable rants). It came with a 1/4" and xlr cables.
Comfort
As mentioned the headband doesn't adjust very far so if you have a large head these may not fit (or you might break em honestly). The clamping force is on the firmer side which maybe troublesome for longer listening sessions but you also have the benefit of them not moving anywhere either. They are equipped with their focus pads (the A version I believe), so the standard hybrid angled pads you'll find on most of their round headphones now. They aren't the deepest pads so your ears may touch cloth that protects the driver. Very note worthy is that the cups do not rotate at all. So unlike say the He400i's if the angle isn't right you may not get a good seal.
Sound
Again I haven't listened to these for long so this is very much my initial thoughts. Right off the bat I wasn't impressed. I was expecting an upgrade of the 400i's which I think are really good but could benefit from a bit more bass. These do have a bit more bass but are overall much darker. The sound stage is very limited causing a very intimate and focused sound. My initial thought was that these were very similar to HD650/6XX and after swapping a bit it would seem that they were aiming for that sound. However the HD6XX, while I never considered them a very spacious pair of headphones, has a good bit more separation of instruments and sounds over the 560's. The 560's just sound congested and end up sounding flat and compressed.
Other thoughts
I don't think I could recommend these. I paid $250 on sale but they normally seem to go for around $350. I would instead recommend grabbing a pair of HD6XX for $200 or He400i's for just under $200. Heck there is even the He4XX which I just realized would be another better pick for under $200. I do think some pad swaps might improve the sound. Some deeper pads should improve the sound stage and potentially alleviate the congestion. I also have a pair of Audeze Vegan pads that could be interesting to test. I'll report back when I get around to swapping pads.
Build
Comfort
Sound
Other thoughts
