Soundmixer
- Joined
- Mar 8, 2021
- Messages
- 571
- Likes
- 392
The guidelines show three layouts for 7.1.6 Atmos, and the one with all Top Speakers is listed LAST, and nowhere mentioned as preferred.
Those same guidelines mention overhead 29 times and ceiling 6 times. Front and rear wall for Atmos speakers is mentioned ZERO times. If you place your speakers on the front and rear walls as you suggest, it will place them too far from the listener to achieve the required vertical angle. Dolby specifies that overhead speakers should ideally be between 30 and 55 degrees (for Front Heights) and 125 to 150 degrees (for Rear Heights) relative to your seated position. If you place them on the front and rear wall, the sound will appear to be coming from "high in front of you" rather than "above you." That is a fact. As I said before, the panner works for overhead speakers; it does support front and rear wall speakers. You can place your speakers wherever you want (there is no speaker setup police), it is your speakers, your room, and your money to waste.
Nor does it mean they are "not Atmos".
If it is not overhead, it is not Atmos. The whole purpose of Atmos is to include overhead speakers over the typical 7.1 or ITU-775 5.1 setup.
Look, all I am saying is that 'Atmos' is a definition with a width that is wider than "only the best and anything less is not Atmos". I think you are having trouble in conceding a small, simple point that I raise (with reference to Dolby's own guidelines), and that should be easy to concede.
Here is what you are missing. Dolby is clear as hell about where they want speakers placed for Atmos. It is clear as a bell they want them OVERHEAD, not on the front wall or rear wall. As I stated earlier, they mention overhead 29 times and ceiling 6 times in their guidelines for speaker setup, but they don't mention the front or rear wall at all. In editing rooms that support Atmos, the speakers are overhead. On the dubbing stage, where Atmos content is mixed, the speakers are overhead. In movie theaters that support Atmos content, the speakers are overhead. No place in the creation and mixing chain will you find Atmos speakers on the front and rear walls. NOWHERE!
Thank you...and with that, your entire argument becomes a waste of time.I immediately concede that matching the speaker arrangements of certified Atmos mixing studios is the best idea of all. No problem.
