Influence of bad soldering jobs
hwlr
S.-W. of France
Hello everyone!
I just soldered a new connector to my headphones' cable and was wondering: is the quality of my... let's say perfectible :D solders influencing the sound?
I can't hear a difference, but the answer may be interesting from a technical point of view.
Thanks!
This might be of interest to some...
This site contains only the NASA Workmanship Inspection Pictorial Reference
All other Workmanship Content has been moved to: https://nepp.nasa.gov/workmanship ------------>
Hello everyone!
Thanks!
If the solder wetted the ends that you are soldering together and there is not too much solder in the joint then it's likely a good joint that will sound fine.
If you want more solder training Pace Worldwide offers excellent training videos and fantastic quality made in the USA soldering equipment.
Unless there is a "cold joint" or "bridge traces" causing a short you won't hear a difference but there may be longer term reliability issues. Here is a link that has nice pictures and descriptions of common soldering issues https://learn.adafruit.com/adafruit-guide-excellent-soldering/common-problems
Great link! I was telling my daughter about cold joints and wetting as we wired a new stereo into her old car. That's a wonderful reference with pictures & explanations of the common problems to avoid and how to fix them.
The resistance can be measured. A multimeter can do that, mine can measure minimum 0.1 ohm at least. The connector adds some resistance and it is not pure copper.
