What about my thread https://www.audiosciencereview.com/...-low-q-subs-quasi-plain-wave-radiation.24396/ ?
And René's thread https://www.audiosciencereview.com/...of-the-double-bass-array-configuration.37943/ ?
The mentioned threads show that constant transducer velosity (not acceleration as for spherical wave) is sufficient for constant spl for a plane wave case. So there is no need for high-Q drivers with a weak magnet.
For a cylindrical wave in an anechoic space, the amplitude drops by 3 dB per octave at a constant , but how do you ensure anechoic propagation of a cylindrical wave in a room?))
Or or place this your line arrays under the ceiling and it will be a CCC.
Take REW RoomSim and HornResp and model, it's simple (but simplified!!).
It's all very simple here:
And here it’s less clear, but also simple and doesn’t require special knowledge:
Four theoretical drivers in parallel and series in aroom infinite horn
(PWT)) 4 meters wide and 2.5 meters high 99999 sq cm cross-section. 18-inch, monster magnets, 28 volts. Gray - anechoic.
Do you have any real room measurements?
I had IB. But then I combined the two rooms into one. When I saw the title of this thread, I thought it was about front and rear IB)).I want an infinite baffle
Create a row of these at half the room's height and a similar row at the rear room end. This will be the DBA. The upper limit will be limited by one transducer at a height of 2.5 m.continuous row of subs across the whole width of the room
