welwynnick
- Joined
- Dec 26, 2023
- Messages
- 1,399
- Likes
- 1,774
Wave Forming, Dirac ART and Double Bass Arrays (DBA) are a revolution in bass management that goes beyond equalisation. They use “subtraction subwoofers” to take bass energy away, as well as adding it. So I wondered how much energy it takes to take bass away?
To keep the box size reasonable, subwoofers force the drive unit to work below the system resonance, so they’re forced to work as static, rather than dynamic transducers, so they’re inefficient.
They don’t need lots of power to move lots of air externally, they need lots of power to compress the air internally, instead of pushing the drive unit backwards and forwards.
Question : can the subtraction subs take advantage of a positive pressure wave?
The pressure waves we hear as sound are very low pressure. The threshold of hearing, 0dB SPL, is generally taken to be 20 µPa, and 100dB is 2Pa, which is tiny. However, subwoofers have to generate much higher pressures inside the cabinet. Consider an example: a 15” driver, 50l enclosure, Sd 840cm2, 101dB at 20Hz at 1m, displacement 700cm3, 8mm travel. When the air inside is compressed quickly, the pressure and temperature rise, so it’s an adiabatic compression, so P1.V1γ = P2.V2γ . The volume decrease here is about 1.4% and the pressure increase is about 2% or 2kPa, or roughly a thousand times higher than the acoustic sound pressure level. An incoming pressure wave is miniscule compared to the internal pressure that the subtraction sub has to generate to absorb it. The answer to the question is no. So is there another way?
Transmission line speakers have always intrigued me. The drive unit doesn’t compress the air in the cabinet in a static manner, it just generates propagating sounds waves that travel around the folded transmission line. The driver doesn’t have to be heavy and inefficient to achieve LF extension, though they never seem to deliver on the theoretical advantages. If the bass wavelength happens to be double the line length, then happy days, but not otherwise. When the frequency gets low and the wavelength long, the transmission line output will start to cancel the driver output and limit the ultimate low frequency extension.
Infinite baffle loading caught my attention a long time ago. The picture above is a typical pair of IB manifolds, with opposed drivers, that vent downwards through the ceiling below. The whole attic becomes the speaker box, so the drivers behave as if they’re in free space, as long as the void is several times the combined Vas of the drivers. I’ve never heard an IB installation, but every single description of the sound has always resonated. It’s not like a box trying to make bass sounds, it’s just there (not unlike my perception of good electrostatic speakers higher up the range). Now I have a handle on that, I wondered if I could take it further.
Imagine I had an IB manifold at the front of the ceiling, and I wanted to “subtract” the bass at the rear of the room, like a double bass array. A positive wave from the front speakers will propagate backwards down the room, while the out-of-phase negative wave in the attic will propagate backwards down the attic. Could I open a hole at the back of the room and let the positive and negative waves cancel each-other out? That would be nice if it worked, and could avoid the need for expensive electronics, but I don’t think sound waves are that obliging. I think both the waves in the attic and the waves in the room would still reflect off whatever they wanted to, rather than conveniently squeezing themselves through some hole in the ceiling.
I think this would work well if I had another manifold at the back of the ceiling, instead of a hole. The speaker would have to be filtered, time delayed and phase reversed, just like a DBA, but I think it would work well.
Could I make an unfolded transmission line in the attic to channel the negative waves where I wanted them, to the back of the room? That’s not very practical because of the roof structure.
How about a false ceiling and a false wall behind the screen that the drivers can vent into? The shallow tunnel would at the same time become a manifold, a transmission line, and an IB cavity. Because the negative waves are out-of-phase with the positive waves, they should cancel each-other out when they reach the back of the room at the same time, like a DBA!
Here’s a two dimensional cross-section through the room to show the concept. I imagine the drivers would be a linear row of several units in a straight line across the front of the room. There would be positive plane waves travelling down the room, and negative plane waves travelling down the tunnel, and forced out at the back of the room. I think the cross sectional area of the tunnel would need to be at least the total area of the drive units.
It's a sort of passive infinite transmission line double bass array, it uses both the positive phase wavefronts from the front of the driver and the negative waves from the rear.
