If you take some time to understand what is offered, I think you will find it quite competitive.
With regards to measurements, there are full CEA-2034 on spinorama.org of two of our three systems if you want to dive in.
You are welcome to stop by. We even cover your travel costs if you end up buying.
Sharp edges causing diffraction is exaggerated. Sharp edges causing audible issues is even more exaggerated. Look at highly praised and well measuring speakers like the Kef Reference series. Hard edges. Or the Genelec 8380A. The latter has slightly rounded edges, but not really much.
Yes, I found the spinorama.org measurements but since they are based on your published measurements they lack measured data due to simulation below 200(?) Hz; and meaningful distortion measurements (as the whole spinorama.org database).
Regarding the speakers you mentioned:
KEF Reference are not their reference speakers as I am sure you are aware.^^ One can see diffraction artifacts or resonances on
KEF's own Reference 5 Meta measurements starting at 1 kHz, as they are present on:
On Axis,
Listening Window,
Early Reflections and
Sound Power. Their true reference speakers, the KEF Blade series do not show these issues at higher frequencies; not even on Erin's higher resolution measurements of the
Blade 2 Meta. Source:
https://erinsaudiocorner.com/loudspeakers/kef_blade2_meta/
Simply put, if money is not an issue and somebody goes for KEF they'd choose the Reference over the Blade only for the looks; not for the sound. PR and marketing is a different story.
Genelec's 8380A is built this way as a
Main Monitor to offer the option for flush mounting in a wall, which will remove such issues (+ SBIR if it is a properly built hard wall like in control rooms). As per their
Operating Manual on page 3: "[...]
When soffit (flush) mounting, the wall surface should extend to the monitor, forming a continuous surface." – which otherwise could not be achieved.
If we take your
Saranna speakers (with somewhat bevelled edges), to have a comparison of single front mounted driver - a coaxial one (with KEF Blade | round edges); especially on your Horizontal directivity / polar map the areas of issue starting at around 2 kHz, then 3 kHz, roughly 4.5 kHz [human hearing's most sensitive areas!], 6 kHz etc. can be easily identified. This also poses a challenge for possible overcorrections during automated room-EQ.
I'll leave it to the eye of the beholder to judge, whether this can be accepted as quite competitive given the price point.
Would your speaker systems offer a built-in fool-proof setup software, since adding (1 or) 2 - 4 (or more) subwoofers is never an easy task, I might be more willing to accept their call for value. In terms of integration into the full system, the only "easy" option is when putting the subwoofer(s) directly below the main speakers so it basically becomes one physical sound source per (stereo) channel. Every other option requires a lot more tinkering. Room simulators only work reliably in "standard" rooms, which almost never is the case. So one would require to place, measure, place, remeasure etc. all subwoofers in different locations to find the right spots. Software would be required which automates these steps and suggests the best locations of all involved subwoofers (and main speakers) based on their measurements (of the single subwoofers and combinations to multiple simultaneous outputs) + integrates them automatically (which probably would require some additional, external "hub" DSP device). Then, further choices have to be made like whether to integrate the subwoofers as a mono channel to flatten room response over a wider listening area or to improve stereo bass - or to do both if subwoofer groups are involved. To crossover (HPF) or not to crossover and so on. Another issue when using cardioid speakers is, that subwoofer integration might "cancel" effectiveness of the main speakers' cardioid bass response if they overlap.
So if a speaker system offered an easy but accurate tool to tackle all these (and more) issues one inevitably faces - and made it usable without asking for a degree in acoustics, then I would be impressed and willing to pay (reasonable) more.
