Nathan Raymond
- Joined
- Feb 5, 2018
- Messages
- 212
- Likes
- 211
On my gaming PC, I have a 5.1 speaker setup, four Micca MB42x:
http://noaudiophile.com/Micca_MB42x_Bookshelf_Speakers/
and a Micca MB42x-C center channel as well as a powered Energy subwoofer (8" downfiring, flared front port, has both sub and speaker-level inputs). Sound source is a Creative Sound Blaster Zx:
https://us.creative.com/p/sound-blaster/sound-blaster-zx
Analog output is via three 3.5mm TRS jacks which I break out into RCA cables. For a time I was using an old receiver that had "6 Channel Direct" input (from the DVD/SACD era when that was a mainstream integrated receiver feature, sadly now a rarity) but the VFD was faded on it and it took up a lot of desk space. I tried a Weiliang Audio 5.1 amplifier from AliExpress (four TPA3116D2, claimed output power is 50W per channel measured at 4Ω), but it made a somewhat loud popping noise through all speakers when you first plug it in, regardless of whether the rotary power knob was in the on position or not, and it lacked much documentation and had some quirks (like three positions for the power knob, when only two seemed to do anything). Anyway, with the FX-Audio FX202A Class D Audio Amplifier 2 x 53W down to $40 on Parts Express, I picked up three of those. No pops, which is good, and according to the manual the specs are:
Chipset: TDA7492PE
Power Output: 53W+53W @ 4Ω, 40W+40W @ 8Ω
THD: 0.06%
SNR: -96dB
Frequency Response: ±2.5dB(20Hz~20KHz)
I was a bit disappointed that on one of the three units the volume knob "0" alignment was different, and while I hoped to be able to take it apart and adjust it so it was aligned the same, I could not find an obvious way to do that, so I'm just living with the difference right now. They don't take up much desk space, which is nice, but I did have to make room for three laptop-style AC-DC power supplies. Would be nice to have a single external volume knob, but I can set the volume knobs on the amps, leave them alone, and then use the Windows volume control as my master volume adjustment.
I also noticed that Parts Express caries the Sure Electronics AA-AB34181 6x100W TDA7498 Class-D Amplifier Board for $70:
https://www.parts-express.com/sure-...100w-tda7498-class-d-amplifier-board--320-307
It seems reasonably well regarded... from a sound quality perspective, would it be any sort of upgrade? Are there any cases out there that could easily house the AA-AB34181, ideally something nearly finished, like what GhentAudio has for the HypeX amps? Part of me would still like a single box to handle this task. One thing that concerns me about the AA-AB34181 being used for PC was this comment from a customer review on Parts Express:
"This is the second unit I purchased. The first had difficulty in handling the signal from my computer. It seems that a High definition audio device is a digital device which uses a 3.3v signal output, which the poor amp tries to boost with fatal results. Make sure of your settings before turning It on."
Does that mean I have to be careful with the Windows volume level if I were to plug the 5.1 analog outputs of the Sound Blaster Zx into the AA-AB34181? i.e. could I destroy it with too much output volume? Not sure I'd be happy with that risk.
Are there any other affordable solutions out there that don't suck?
Chipset: TDA7492PE
THD: 0.06%
SNR: -96dB
