Oops; thanks for the correction.Ahem, the microphonic voltage of a VC is always proportional to velocity at all frequencies.
Better control of diaphragm motion does not follow from load invariance. Whether a diaphragm is pistonic at a given frequency is virtually entirely determined by its mechanical design, not anything to do with the driving amplifier. Load invariance is a result the output filter being subject to negative feedback control (i.e. inside a feedback loop). Linear amps (class A, A/B, B, etc) are almost always "load invariant" in this sense without any fancy feedback techniques because they do not require output filters like class D does.DF itself was not a factor of increased control, but an indication of it, because it rises as a side effect of effective negative feedback and loop gain application, which, as you indicate, DOES improve load-invariant response and thereby pistonic driver behavior.
