damaged_goods
- Joined
- Apr 19, 2021
- Messages
- 19
- Likes
- 31
I have a setup where I have my Yamaha AVR running as a preamp into a HT bypass input on my integrated amp, which then acts as power amp for the front channels when watching movies. For two channel music listening I have a WiiM Ultra streamer connected to one of the line inputs on the integrated amp. So the same L/R speakers and power amp section are used in both cases, but with different pre-amps.
The AVR, which is now some 8-9 years old now, has a somewhat limited PEQ functionality with 6 bands for L/R with only a few predefined frequencies to choose from. The lowest possible frequency to set is 62.5Hz.
I have a huge room mode peak at around 45Hz that I can correct with PEQ on the subwoofer (or on the front speakers when using WiiM's PEQ). For L/R I have manually tuned the EQ and bumped the mid bass, which is attenuated due to limitations of the room (geometry/asymmetry size, etc).
The weird thing is that after applying PEQ on the AVR, the 45Hz peak is diminished, even with no subwoofer/active bass management and no corrections done below 62.5Hz. I first thought that perhaps the bumped up mid bass would effect low bass too, due to interaction with the room, but when applying the exact same PEQ filters in my WiiM Ultra, I get a completely different result, where the 45Hz peak is still there, and the effect on the mid bass also looks very different. Increasing the mid bass on the WiiM also results in quite audible distorsion, even after compensating by lowering pre-gain to avoid any clipping, which is not the case with the AVR.
Does anyone have any idea of what Yamaha might do in their filtering that has this kind of effect? I find it very peculiar...
Here's the in-room frequency response with no EQ applied for both the AVR and the WiiM Ultra. As you can see the graphs are matching. No big differences.
Here's the graph for the EQ'd response on the AVR, where the 45Hz peak is mysteriously gone:
And here we see the same graph as above, but also the response from my WiiM Ultra with the exact same PEQ filters and a completely different result. (Again, no subwoofer enabled in any of the measurements. Just L+R stereo.)
And here's the PEQ filters applied (on both L and R channel):
