A 6th-order bandpasses are severely bandwidth-limited. I'm not sure it's a good idea to run them up to 200 Hz. Bose thought it was a good idea though...
I would just go with the push-pull closed system. It will give you double the air moved vs Isobarik. You'll just need more power. The two Seas drivers will only need 36L to be happy. Even in 25L, they will do fine, maxSPL is the same, you'll just need about 350W and you'll still get 100+ dB at 30Hz. Coupled with room gain, that will be even better. That is very respectable for such a small box. And you'll have two!
You could also look at 4x 5.25/6.5" to complement the MTM in looks. You may also be able to utilize the full enclosure volume by simply adding a sound-absorbing barrier between mid and bass, blocking midrange, but bass not so much.
