terryforsythe
I'm confused. The configuration in your latest drawing is not isobaric.In an isobaric configuration
Ah I see. Ok so the volume of air still needs to be encapsulated. I thought it was just merely making it push-pull. My bad...I'm confused. The configuration in your latest drawing is not isobaric.
Where is the acoustic output coming from?Much better...
In an isobaric design a first woofer has one side exposed to the inside of the cabinet, and the other side pushing a second woofer. The opposite side of the second woofer provides the acoustic output. I.e.:
The top picture is with the woofers wired in phase. In the bottom picture they are wired out of phase. That way, both cones are always moving in the same direction.
I'll be using both sides. As one driver pushes, the other becomes the acoustically driven pull and outputs the signal through the ports. In essence I'm using both sides of the enclosure as one large port.
Wouldn't that make it an 8th order then?If the port openings are just at the top OR just at the bottom, I think that configuration would be a "4th order isobaric bandpass" enclosure. If there are port openings at both the top and bottom, I don't know what it is.
I've used the RS225 in an isobaric two-way. Isobaric is quite inefficient but can work well in certain situations. Be warned that there is something WinISD calculates wrong for isobaric - I don't remember what it is but maybe impedance or total SPL.Have you tried any of their reference stuff?
Works for me! Although, funny enough, isobaric actually gives me a bit of wiggle room. Got about 32 liters of play, but that's also without me lining and dampening the enclosure.I've used the RS225 in an isobaric two-way. Isobaric is quite inefficient but can work well in certain situations. Be warned that there is something WinISD calculates wrong for isobaric - I don't remember what it is but maybe impedance or total SPL.
a4eAudio.com - Bosi 225
My Bosi 225 design was created as an entry to the 2023 InDIYana theme competition. Surprisingly it won 1st place. Below is a write-up of how the speaker came about and some of the decisions that I made in building and designing it. Tweeter: Satori TW29RN-B-8 Woofer: Dayton Audio RS225-8 (x2www.a4eaudio.com
I've also used the 4 inch RS100 and 10 inch paper cone RS270P-4 but it looks like they discontinued the 10-inch versions in the last month or two. In general the Reference Series (aluminum and paper) are great for the money.
That's verging on floorstander territory already... Maybe you could make things easier on yourself and do "bass modules" / subwoofers with the SEAS drivers and stick the MTMs on top? Still somewhat portable but you won't have to go through all these tricky designs getting them all in one cabinet.10"W 19.5"L 27"H
Nah no worries budThat's verging on floorstander territory already... Maybe you could make things easier on yourself and do "bass modules" / subwoofers with the SEAS drivers and stick the MTMs on top? Still somewhat portable but you won't have to go through all these tricky designs getting them all in one cabinet.
Sorry that I am always trying to talk you out of stuff.![]()
It looks like I was editing my post while you were posting.Wouldn't that make it an 8th order then?
Which specific Dayton driver are you considering? The only specific one I saw mentioned was the Ultimax....the daytons in iso only need a little over 9 liters, which is more than doable.
Using a Hypex 253 so 2 ohms for me bbyYes those are good. Note, for isobaric you will wire two in parallel so would need to get the 8 ohm version, when wired in parallel will give you 4 ohms.
Great detective work! I hope it meets your design targets.@Duke found an answer!
According to WinISD, it would be a 6th order bandpass.
