In-line 10 band PEQ without USB input
Hello
I was wondering if anyone could point me in the direction of a particular device that is basically like a Fiio BTR13 (for the 10 band customisable PEQ) but instead of having a USB input, would be a jack input? Could be powered off USB or DC-in or battery, no real issue. Ideally similar portability as the BTR13. The idea is that i play drums in a band, and would like to have my monitor feed EQ'd to a particular curve that fits headphones/IEMs that i might use, similar to equalizer APO. Only real solution i could think of for having a sef contained powered device is something like a DEQ2496 but its pretty huge :D
Has to be a jack/xlr input tho, and can't use bluetooth output due to latency (playing live).
Any and all suggestions welcome, thank you! :)
I get the feeling something like the mini-dsp 2x4 HD would be along the lines, but ideally something smaller is what im looking for.
That's one requirement too many I'm afraid.
No thumb drive sized DAC+Amp with Line in and PEQ exists.
The closest things I can think of are:
-miniDSP PocketADC + Topping DX5II/JDS Element IV
-miniDSP 2x4HD/WiiM Pro + Headphone Amp (e.g. L30II)
-DIYAH Kameleon
Could it drive an IEM?
It's not designed to handle low impedance loads.
Sound will come out, but the WiiM will be overstressed and is likely to change the IEM's tonality due to insufficient damping.
See here:
Stereophile measured the Mini's output impedance at 33Ω, so you can put that into the spreadsheet and see the worst case frequency response impact.
Sweet, this could work then....
Desk jack monitor aux output > 3.5mm converter > Wiim mini aux input > peq through wiim > wiim mini aux out > 3.5mm to dual mono 6.35mm splitter > stereo belt pack headphone amp/ mini mixer > iems.
Could work but you will pick up some latency from the WiiM, it's not designed for live use.
Old Skool: Yamaha YDP-2006. It's six (per channel) fully parametric bands instead of 10, but fulfills all the other requirements. It's digital processing, balanced analog ins and outs, switchable pro (+4 dBU) or consumer (-20 dBU) input levels, settable levels, bypass, multiple sets of EQ settings, etc., etc. Channels can also be time-delayed. Just stereo. I have a couple and paid about a hundred bucks for each.
1-ydp2006-1-jpg.47507
Rick "not smaller, though" Denney
