RomfordNavy
- Joined
- Feb 4, 2026
- Messages
- 27
- Likes
- 1
Due to limited space I am now looking at the possibility of through-floor mounting (floorboards) but have a few questions on this:
- Would it matter much if it were covered by carpet as I am reluctant to cut holes in an expensive bit of 35' long carpet? I hope that wouldn't absorb much in the way of very low frequencies would it.
- Might even need to have some thermal insulation like a sheet of foam rubber covering it to keep the cold out during the winter, is there anything which has good thermal insulating properties but allows low frequency sound to pass through?
- Apart from the small resistance to air-flow from the carpet, thermal insulation and possibly floor joist would this effectively be like an infinite-baffle?
- Cone could be facing upwards or downwards depending on exactly how I implement this and may be in a shallow box sitting on top of the carpet with a hole in the floorboards beneath.
- Would it help to have a very large right-angle box or tube on top so as to direct the output towards the listener or is that irrelevent with sub-bass?
